Old 01-31-2013, 04:32 AM   #19
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
HAHA, yea they are, refer back to this thread for more details. good eye
http://yarisworld.com/forums/showthread.php?t=43377
-Derrick-
Old 01-31-2013, 12:54 PM   #20
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
i was actually looking at them(on discount tire) before you made the post, so i immediately noticed them. I want some but haven't the cash flow right now or a wife that thinks they will go with my red yaris.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood
Old 01-31-2013, 01:48 PM   #21
ilikerice
ilikerice's Avatar
I dont think red will look good on red. But they have white. That would look nice.
-Derrick-
Old 02-01-2013, 04:22 PM   #22
ilikerice
ilikerice's Avatar
Who likes PICTURES?!?!?!
Head and block completely disassembled. Waiting for owner to let me know if he wants to take to machine shop to give it a hot bath, or for me to do a simple wire brush and brake cleaner wash. Got the bearing colors also, gotta wait for those to come in and the rest of the parts.. YAY, fun stuff.
Cylinder walls are still within spec, no scorching or scratches, crankshaft is in top notch. Bearings were just a little discolored, but nothing to be too worried about. New ones while its out, why not? For 310k miles, doesn't look a mile over 50k
-Derrick-
Old 02-01-2013, 05:57 PM   #23
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
Look at those cute little pistons!
MicroImageonline forums - Shroomster
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 02-06-2013, 05:08 PM   #24
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
Nice build.
Are you using those original pistons or replacing them with after market? I bought a 1.6 ltr Daihatsu 16 valve motor a few days ago and started pulling it apart. Never done this in my life. But what the heck!! Gonna use the 1.3 ltr piston, distributor and manifold that i have in my 1.3 ltr engine in the car right now.So that the sensors and connectors don't have to change.TAKE out the 1.3 bolt in the 1.6, plug and play!! 1.6 has more torque, if the 1.3 rev happy engine is anything to go by. Damn, this 1.6 HD engine is going to be like a pocket rocket go kart haha.Sorry to high jack your thread.
Old 02-06-2013, 08:53 PM   #25
ilikerice
ilikerice's Avatar
HAHA.. yea, I remember going from a 1.5 duel port injection motor CRX DX to a 1.8 integra LS motor. almost a 50hp jump but god you feel every bit of it in a light 1900 lbs. car. gezus. Then I got used to it and wanted more power. Did a B16 (vtec) head swap.. mmm. that was fun, but not enough.. had to go turbo.. 215whp on 10psi.. I miss that car so much.. I hope my yaris can do the same one day..
I don't know much about Daihatsu, but I do remember seeing a thread on a rebuild, I think that might have been you.
To answer your question. yes, I will be using the same pistons. just replacing the rings. Pistons still look good. no scratches and the cylinders are not oblong
-Derrick-
Old 02-06-2013, 09:06 PM   #26
ilikerice
ilikerice's Avatar
Oh, and quick update. I dropped off the block and head at a machine shop to get a hot bath and pressure washed. Most of the parts just came in yesterday. Just waiting to get a call back from machine shop. I wont be able to do anything til next week anyways, going to Knoxville, TN this weekend to visit friends.
-Derrick-
Old 02-08-2013, 07:31 PM   #27
junorico24
junorico24's Avatar
That block looks in good shape, any chips on the outer cylinder walls? What parts are you replacing?
Old 02-09-2013, 06:14 PM   #28
ilikerice
ilikerice's Avatar
nope. block is in amazing shape.
replacing:
all gaskets and "O" rings from a honda OEM Upper and Lower Gasket kit
oil sump
oil pump
water pump
timing tensioner
T-belt and Accessory belts
piston rings
new oil pan (original threads for the plug are cross-threaded)
rod and main bearings
new clutch disc and throwout bearing
new radiator and vacuum hoses
I feel I am forgetting something. but I think that is about it though
-Derrick-
Old 02-12-2013, 04:27 AM   #29
ilikerice
ilikerice's Avatar
back from the machine shop. pretty
-Derrick-
Old 02-12-2013, 01:33 PM   #30
Golddeenoh
Golddeenoh's Avatar
oooo pretty :D
some serious machine shop to deliver at 4am :P
Old 02-17-2013, 09:23 AM   #31
ilikerice
ilikerice's Avatar
time for lapping valves.
thought I would do a DIY bit here also
pic1: Tried to clean these exhaust valves but they are done. Can't get all the carbon off them without damaging them. Gonna have to order new ones
pic2: before and after cleaning. cleaned up nice and smooth.
pic3: I use a stainless steel brush to clean the valves and also the pistons
pic4: dirty piston
pic5: clean piston
pic6: now to lapping valves. Here we have cordless impact (or drill, I just love my Makita. my fav tool.), T30 bit, and a vacuum hose
pic7: Valve grinding compound
pic8: first you want to coat the valve with a little bit of compound on the edges where it contacts with the head
pic9: Insert valve, try to start with the #1 cylinder and work your way up. Keeps things in order. When doing this each valve is being fitted specificly to each separate opening.
pic10: on the other side, connect the hose on the T30 and the other side to the end of the valve. When spinning the valve on the head go at a slow/med speed. Let the valve spin on the head for a couple seconds then release. Repeat this a couple times. Then remove the hose from the valve and pull the valve out
pic11: Clean the compound off the valve AND the head. You want to see a solid grey ring around the valve. This will allow the valve to seat fully on the head for a good seal when closed. If you see any pin needle dark spots (pitting), repeat from pic 8. When you finish, take a sharpie and write on the bottom of the valve E1 (exhaust #1) or I1 (Intake #1) depending which valve it is. You want to keep these in order when you get ready to install them.
pic12: Finished the Intake side. gotta wait for the exhaust valves to get here to finish those and then I can finish the head.
-Derrick-
Old 02-17-2013, 09:28 AM   #32
ilikerice
ilikerice's Avatar
next, honing the pistons
Using a honing tool and cordless drill basically you insert this inside the cylinder and slowly spin it with and up and down motion about 5 times. Just trying to get a crossed etches in the cylinder walls. When finished, grab a paper towel and put some oil on it. any motor oil will be fine. and coat the cylinder walls with oil.
Still waiting for the piston rings now.. so
-Derrick-
Old 02-17-2013, 10:16 PM   #33
junorico24
junorico24's Avatar
WOW
Old 02-19-2013, 06:39 PM   #34
Shroomster
Shroomster's Avatar
Really hating the "unsubscribe" option on control panel......
Old 02-20-2013, 04:43 AM   #35
ilikerice
ilikerice's Avatar
LOL, *side note*
in pic 1 and 3 you notice my index finger is exposed form the glove. This was not on purpose. When using a Dremmel, should always use caution. While polishing the valves, it got away from me and hit my finger. Snatched part of my glove off. didnt hurt, but scared the crap out of me.
Another thing, where safety glasses or a face shield while using the stainless steel. Those little bristles after a while become weak and turn into hair thin daggers. They don't hurt when they hit the skin, but I can only imagine the pain if one gets in your eye. I had 1 or 2 stuck in my finger.
-Derrick-
Old 02-20-2013, 09:06 AM   #36
Golddeenoh
Golddeenoh's Avatar
"no more important rule than to ware these, safety glasses"
rebuild yaris9876 Performance Modifications 6 12-21-2011 02:43 PM
The ugly ugly UGLY rim project thread. ('86 CRX wheels) 33OH Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 01-07-2011 01:35 PM
crx sir jdm front bumper, cf hood, headlights ilikerice Items for Sale by private party 0 12-27-2010 08:19 PM
Engine Rebuild rkvin21 Forced Induction Forum 0 02-25-2010 12:19 AM
Rebuild some threads? Reddog99 Suggestions - Feedback - Questions 2 10-22-2008 09:20 AM
