Old 02-17-2013, 12:02 AM   #109
YarisPH
Drives: 2008 Yaris Sedan
Hi guys! First post here but been lurking for a while. Just wanna say thanks to the one who made this DIY guide! I used 2 quarts of Redline MT-90 on our 2008 Vios (Yaris sedan's name here in the Phils.). Car has 42K ++ kilometers on the ODO. Will observe the gear changes later on, as I've read a lot of good feedbacks on this oil. Many thanks again Yarisworld. :)
YarisPH is offline   Reply With Quote
Old 03-28-2013, 01:06 PM   #110
elo179
Drives: Yaris 2007
Can someone post a link to Amazon with Red Line that's MT-90 GL4 75w90 that has been recommended.
I can only seem to find MT90 that is 90w. Or if I do find the 75w90 MT-90 it's in 5 qt.
I don’t know the difference from 75w90 and 90w but it seems most of you are recommending the 75w90.
If possible would like it sold or shipped by Amazon to take advantage of prime shipping.
elo179 is offline   Reply With Quote
Old 03-28-2013, 01:09 PM   #111
hw6515
Drives: 08 Yaris AT, 350Z GT MT
did you try:
http://www.amazon.com/s/ref=nb_sb_no...T-90+GL4+75w90
Be careful with amazon prime.......it's kind of addictive ;)
hw6515 is offline   Reply With Quote
Old 03-28-2013, 01:15 PM   #112
elo179
Drives: Yaris 2007
Thanks for the quick reply. Do you know if the oil link below is a 75w90, I know Amazon doesn't always do a good job with product descriptions and it say's 90w but am not sure if there is a difference.
http://www.amazon.com/Red-Line-50304...=cm_cr_pr_pb_t
Old 03-28-2013, 01:20 PM   #113
hw6515
Try this link, still prime.
http://www.amazon.com/Red-Line-50504...T-90+GL4+75w90
Old 03-28-2013, 01:58 PM   #114
Hershey
Go here to possibly find a local dealer , http://www.redlineoil.com/dealers.aspx and here for details http://www.redlineoil.com/product.aspx?pid=46&pcid=7 . Let us know of your purchase and if any improvemnets in performance .
Old 03-28-2013, 02:12 PM   #115
elo179
Drives: Yaris 2007
No local dealers within 50 miles. :(
Old 03-28-2013, 03:03 PM   #116
elo179
Drives: Yaris 2007
Originally Posted by hw6515 View Post
I looked at that and it's 85w, not sure what the difference is from 90w but Amazon tells me that it's not compatible with my Yaris :)
Which is an 07 manual hatchback that lives in the south Texas heat.
Old 03-29-2013, 12:05 AM   #117
Hershey
elo179 , you could ask a local private owned auto parts to possibly order it for you . That's what I did . AMSOIL has MTG ( 75w-90 , GL-4 ) synthetic and is usually easier to purchase . MTG , http://www.amsoil.com/shop/by-produc...r-lube-75w-90/ . Good Luck .
Old 05-17-2013, 10:27 AM   #118
regal
Drives: 09 Yaris 3 Dr White LB
Anyone have a part number for the drain plug washer?
regal is offline   Reply With Quote
Old 05-17-2013, 07:15 PM   #119
jason214
Drives: 2007 Yaris Hatchback
Drain/Filler Plug P/N: 90341-18033
Drain/Filler Plug Gasket P/N: 90430-18008
jason214 is offline   Reply With Quote
Old 06-09-2013, 01:34 AM   #120
wilbrod
Drives: Yaris 2008 Hatchback
Thanks for the tutorial. As mentioned by others, the oil did gush out. All the oil must have come out in less than 5 seconds. I was thinking of letting it slowly drip out when it started coming out just before the bolt comes completely out and I should have :)
Somehow I had never changed the oil for the manual transmission and it was probably [over]due, currently sitting at 147 000 km... lots of highway kms but should have done it before.
I used the marker trick and it worked really well for the top bolt. Bottom one fell in the oil pan and the mark came off.
Filling it up with a funnel from Canadian Tire with a hose attachment worked like a charm.
Looking up from underneath:
Where I put the funnel. I moved the air filter cover sideways a bit to make the funnel go in a little more
Funnel used:
Cheers!
wilbrod is offline   Reply With Quote
Old 06-09-2013, 02:16 PM   #121
Hershey
Well done . On occasion during an oil change I drop the drain bolt in the oil bucket and have to fish around for it . Keep us informed on any improvements with the new fill . Well worth the mess .
Old 06-09-2013, 11:41 PM   #122
wilbrod
I was a bit doubtful that I would see any difference as the shift stick was moving around really well with the old oil. Well now I can hardly believe it but it is actually slicker. I would think that the biggest difference will be in winter driving.
Oh and I didn't have a 24mm socket or a 1/2" ratchet(as most 24mm sockets seemed to be 1/2" inserts). Found many at the pawn shop. Got the ratchet AND the socket for $4 all in!
Old 06-09-2013, 11:57 PM   #123
Hershey
Can't go wrong at that price . Lady luck must be on your side .
Old 07-04-2013, 10:19 PM   #124
7:34pm
Drives: 07 Yaris
Sorry but my Yaris is base model and didn't come with an owner's manual.
What type of fluid is recommended for the 5spd manual? Is it 75w90?
thanks
7:34pm is offline   Reply With Quote
Old 07-05-2013, 06:56 AM   #125
bronsin
bronsin's Avatar
Wilbro how did your engine compartment get so dirty?
I hope you changed the AF too!
Old 10-25-2013, 02:37 AM   #126
Nigel8600
I was having the same problem shifting into first (at a very slow speed, maybe 2MPH?) so I found this thread and changed my gear oil to MT90 2 days ago. I cant believe how smooth it shifts now, its like butter........ BUT............. it still grinds when going into first... even when going into 2nd gear just before. Agghhhh
Nigel8600 is offline   Reply With Quote
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 10:22 PM
Yaris Auto need help with tranny oil change chrisada_to2a General Yaris / Vitz Discussion 2 05-17-2007 02:51 PM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 09:37 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-08-2006 12:21 AM
