Old 02-24-2013, 10:35 AM   #1
Yarflana
Drives: 2008 Base Model
RPF1 center cap weight
See here to ensure you know what I am referring to:
http://store.enkei.com/product/enkei-rpf1-cap
Does anyone know the weight of a cap? They are aluminum so they cannot add that much more weight, but I am curious because since the point of buying the RPF1s, at 13.7 pounds for 16x7s, is obviously to reduce weight. If they are more than 1/2 pound a piece, I will not plan to get them.
However, my only question is whether for acceleration, they shouldn't affect things much since they are not adding weight to the outer diameter of the wheel, but only at the center, so they are more of a static weight, vs. a kinetic weight (I know there are better terms for this, but I think you racing folks know what I mean).
Thoughts?
Thanks,
Pat
Yarflana is offline   Reply With Quote
Old 02-24-2013, 10:56 AM   #2
NJ Drive
Drives: 2012 Yaris SE
Center cap weight is insignificant(an ounce or two at best), especially residing at the center of the wheel. If you're going to be anal about moment of inertia, concentrate on lowering tire weight and reducing its overall diameter since it will have the most dramatic effect.
NJ Drive is offline   Reply With Quote
Old 02-24-2013, 02:50 PM   #3
Yarflana
Hey thanks a lot...exactly what I wanted to know. Take care,
Pat
Old 02-24-2013, 04:58 PM   #4
Klink10
Klink10's Avatar
I have 4 of them and they weigh almost nothing. So much so that if you drop one it will dent.
Rotated my Drag Dr24 rims, now the center cap won't fit on one rim. mazilla Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-06-2011 12:40 PM
Center Cap Question TwoBearWisconsin Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 10-28-2010 07:39 PM
center cap question Billiam Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 04-13-2010 10:07 PM
Weight Reductions scape General Yaris / Vitz Discussion 34 06-08-2009 02:31 PM
Center Cap help Brian Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 02-25-2009 07:18 AM
