Old 06-05-2011, 01:50 AM   #1
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Rotated my Drag Dr24 rims, now the center cap won't fit on one rim.
Strangest thing, like the title says I rotated my rims/tires today for the first time since buying them(about 9k miles). When I went to lock down the drivers side front(was the drivers rear) I noticed the center cap was now hitting the axle shaft well before any portion of the cap could be seated. I switched caps with the rest, no luck. I rotated the rear back to the front and it fit fine. I checked the stampings on the back of the rims and they are identical.
If I had to guess(which I do at this point) I'd say that one rim is out of spec. I've never come across this before, I even took it to two separate shops and nobody at either had seen that before. Finally I went to see the shop I got them from and they were also baffled. They're contacting the Mfg. on Monday.
Anybody here come across this problem before???
-Type 07 FFL-
My odometer 03/11
Old 06-06-2011, 06:01 AM   #2
rick996
rick996's Avatar
Drives: 2010 5 door hatch w/5 sp man.
Do you have centering rings? It is possible that the centering ring stayed with the driver's rear axle instead of the wheel.
rick996 is offline   Reply With Quote
Old 06-06-2011, 08:20 AM   #3
^ +1
I've done it, and seen others do it as well. One ring stuck to the hub, while another is in the wheel about to be mounted. Brief WTF period, followed by quick realization of the situation.
Old 06-06-2011, 12:40 PM   #4
mazilla
advocatus diaboli
mazilla's Avatar
It's not the hubcentric rings.
-Type 07 FFL-
My odometer 03/11
Consumer Reports not too pleased with Yaris Befuddled General Yaris / Vitz Discussion 132 02-28-2011 02:57 PM
center cap question Billiam Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 04-13-2010 10:07 PM
RIM FIT dougb Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 09-30-2007 08:24 PM
