Old 03-12-2013, 09:07 AM   #73
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
so you're not even running an air filter or did you just have it off?
I like how the turbo is on top of the motor so it can be seen.
Old 03-12-2013, 11:48 AM   #74
Sweet!
Old 03-12-2013, 06:10 PM   #75
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
I have been running a filter over the years, with this turbo I wanted to try a velocity stack. A 6'' air filter is available though. Since pieces of spark plug already had their rounds inside my motor, dust doesn't concern me at this moment.
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 03-12-2013, 06:18 PM   #76
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
if you are not first, you are last :P
Old 03-12-2013, 06:19 PM   #77
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
My buddy has his intake direct vented in through a custom "port" where the driver's headlight would be
He said that seeing as how he is always running at high rpm whatever comes in he feels is disintegrated anyway.
Old 03-12-2013, 08:12 PM   #78
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
That turbo pic is sexy! Kudos
pimp my yaris is offline   Reply With Quote
Old 03-12-2013, 10:27 PM   #79
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
It looks like a BLOX 6 inch velocity stack air filter would fit right on there...
I think K & N also makes one, although I like the BLOX better because it's a dry element and I don't need to mess with oiling it.
Old 03-12-2013, 10:36 PM   #80
yaris2010RS
yaris2010RS's Avatar
LOVE IT! Definatly gonna try a top mount turbo when i rebuild....
Old 03-12-2013, 11:27 PM   #81
And ruin the effect of his nicely radiused velocity stack. That curved edge (all of it) is critical to draw in and accelerate the incoming air.
Old 03-13-2013, 01:18 PM   #82
tooter
play every day
tooter's Avatar
Hey Garm,
I was just thinking of engine longevity from not sucking abrasive dirt particles into it.
The full 180 degrees of the velocity stack profile actually extends well into the air filter because it attaches to bottom edge of the skirt...
...and those 6 inch filters are massive.
Old 03-13-2013, 02:29 PM   #83
fnkngrv
fnkngrv's Avatar
Originally Posted by tooter View Post
Hey Garm,
This is what I was referencing in a previous response. My buddy's SR20 set up has:
With the rpm's produced along with speeds he pretty much has not seen any issues inside his engine from running with a "direct" porting through the driver's side headlamp assembly. Sure, there could be a possibility, but when you are racing you are always aware of what is going on and used to taking calculated risks.
Old 03-13-2013, 02:41 PM   #84
tooter
play every day
tooter's Avatar
Competition is a totally different mindset where winning races outweighs making an engine last 100,000 miles.
Running like that would creep me out. What happens if another racer's tire kicks up even a small rock and it gets sucked into the turbine impeller and into the engine?
Old 03-13-2013, 02:43 PM   #85
Old 03-13-2013, 06:14 PM   #86
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Ive seen many drag cars run the headlight ducting, nothing wrong with that. Road racing, yea a lot of debris come from sticky tires ahead. I do have a screen in front of turbo in case somebody gets the bright idea to chuck a pebble in my turbo during a meet.
Ptuning.com
Old 03-13-2013, 07:07 PM   #87
^ Eww, that's evil.
Old 03-15-2013, 11:43 PM   #88
Focus_Sh1ft
Focus_Sh1ft's Avatar
I like everything I've seen here. EVERYTHING.
Old 08-25-2013, 10:12 PM   #89
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
bump
Ptuning.com
Old 08-25-2013, 10:21 PM   #90
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
and dennnn...?
