Old 08-25-2012, 06:09 PM   #1
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Going for broke
My greedy mind has taken over my satisfaction of having a dead reliable setup. Im putting my car back on the dyno, with race gas (C16) and targeting boost to 35psi . I have no idea if the motor will survive. This motor has 45,000 miles of racing and daily driving, but it has been solid thus far. Only thing I have to upgrade to achieve that boost is my map sensor ( current one maxes out at 30psi).
September 3rd Im headed to the dragstrip, and will post results. Hoping for 11.7 @125mph... which would be insane
Ptuning.com
Old 08-25-2012, 06:13 PM   #2
b20vteg
no show, no go :(
b20vteg's Avatar
Drives: 2012 yaris 3dr hb
sweet, good luck... can't wait to see results!
b20vteg is offline   Reply With Quote
Old 08-25-2012, 06:15 PM   #3
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I have a feeling the 1NZ will take it like a champ. Good luck regardless!
Old 08-25-2012, 06:20 PM   #4
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
will be interesting to see...I am figuring that my boost will need to be that high if not more next summer to achieve my goals.
Old 08-25-2012, 06:53 PM   #5
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Hmmm that might be too much. It's not sleeved if I remember but you won't know till you do it! Go for it
Old 08-25-2012, 06:57 PM   #6
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Im thinking head gasket will go first, on factory head bolts. Only one way to find out!
Ptuning.com
Old 08-25-2012, 06:58 PM   #7
scioncrew
scioncrew's Avatar
Drives: SCION tC
Send a message via AIM to scioncrew
GOOD LUCK MAN! you got it. let it eat in second gear keep us posted
05 Scion tC allmotor 350+ hp 9.34@144mph
05 Scion tC sfwd 880hp 9.96@147mph
05 Scion xB 280hp 12.97@104mph
07 Toyota Yaris 357hp 12.80@107mph
scioncrew is offline   Reply With Quote
Old 08-25-2012, 08:52 PM   #8
Woooo!! Go for it!
Old 08-25-2012, 09:06 PM   #9
fnkngrv
fnkngrv's Avatar
125mph in 2nd gear....now THAT would be impressive...lol
Old 08-25-2012, 09:13 PM   #10
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
Is yout head upgraded ?
Interior:ALL red, black roof
Old 08-25-2012, 09:49 PM   #11
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
stock head, stock block with pistons and rods. Ive been on the 27psi tune for a long time, just want to tune beyond with race gas (same map) for drag use only. If the motor survives the dyno and a few drag passes at that boost, then the boost is coming back down.
Ptuning.com
Old 08-25-2012, 09:52 PM   #12
So you can just up the boost and run it without any additional tuning? that gives me ideas...
Old 08-25-2012, 09:54 PM   #13
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
lol. I think he means don't pedal 2nd. Couple changes since last 1/4 mile visit also includes a Kaaz lsd along with Yaris gears, 2nd gear should hook for sure w/slicks at MIR. MIR is always prepped very well.
Ptuning.com
Old 08-25-2012, 09:57 PM   #14
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
oh no.... what I am saying is beyond 27psi the map will be for race gas . Basically a continuation of current tune. Tuning it this week.
Ptuning.com
Old 08-25-2012, 10:50 PM   #15
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
It will be good to know what the limits of a none sleeved 1nz will be capable of. I would love to try that with stock compression and run E85 fuel with a proEFI stand alone $$$$.
Garms co worker was telling me that someone was possibly coming out with a main cap girdle for the 1nz. I bet that could extend your limits with all alluminum block.
Old 08-26-2012, 12:23 AM   #16
fnkngrv
fnkngrv's Avatar
Oh I know...but just saying if someone was able to do 125 in 2nd gear that would be insane...impossible I would imagine, but insane. I do know that my buddy's nissan hardbody can get to over 160 before shifting out of 3rd. I will have to ask him for grins again what he shifts at from 2nd on his sr20. I will also have to jog my memory on what tranny/rearend he is running.
Old 08-27-2012, 08:30 AM   #17
thefalls
Drives: Axio GT
Limits are going to be pushed and all of us will find answers to so many questions.
Good luck!!!
thefalls is offline   Reply With Quote
Old 08-27-2012, 04:19 PM   #18
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
Didn't someone run a built 1nz-fe with about 32psi to 501whp, so in simple theory a your 35psi could cross 400hp and scare more of those V-8 guys at the track. the trick will be being able to get traction off the line with out spinning the wheels and blowing the engine. this is surely a curious set to see what happens.
