#1261 |
Thank you :)
also, I forgot to post my wheel / tire size. 15x8 et25 with 195 55 falken ziex 512's. :) Gah, those look so much better on your car than they did on mine. lol. |
#1262 |
Do Mini wheels count? I like these.
#1263 |
![]() ![]() ![]() ![]() Drives: 06 Yaris HB CE Join Date: Aug 2009
#1264 | |
![]() ![]() Drives: 2010 light blue yaris sedan Join Date: Feb 2013
#1265 |
Every time I read "camber" I say... don't do it unless you can afford tires. $$$$
Due to the geometry of the Yaris camber eats the tires making them NFG Camber looks really good in my car but I had to take it way. D.
. CLA 250, 4MATIC |
#1266 |
![]() ![]() Drives: 2012 Yaris LE Join Date: Oct 2012
I got a set of Drag DR-19's from 1010tires to take advantage of their free shipping in Canada event. I plugged my car into the configuration tool and it came up with a list of rims that would fit my stock car and tires. Went to Costco this morning to get my stock tires installed and they wouldn't installed the tires on the rims saying the rims were too wide for the tires.
![]() The rims are 15X7 and the stock rims are 15X5. Would 1" on either side make that much of a difference? If this post is in the wrong thread please move it. |
#1267 |
stock as in 185 ... if so that would be little narrow for 7 inch rim ...but if u really want them on try a different shop cos cosco has some stupid rules they will only go by what the book specifies for the car anything out of range and they can and will refuse the work.
#1268 |
Stock as in 175/65/15.
#1269 |
wow...no that wont work on a 7 inch rim..think u need to get some tires ...sorry .
try active green and ross they have awesome deals also there is a tire rebate on good yr 100 bucks off michelin 70 yoka 70 bf 50 general tire 35 pirelli 100 bridgestone 70 continental 65 dunlop 40 mail in if u buy 4 |
#1270 |
Why in the hell would 1010tires suggest these rims when my tires are 175? Man I'm pissed at 1010tires right now.
Actually here is a tire wheel package they sell. Same rims I got with same size tires I have. How car they fit if the rim is too wide?
#1271 |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
that is odd, i had Drag DR19s on my car for years and the stock size was 185/60 15, is there that much difference between the Canadian version and the USDM version? see if you can change the tire size and order the 185s instead, not to mention that the wider tires will give you better traction and increase in handling.
I had a Toyota dealer change my tires over from the stock steelies to the drags, no issues but i'm pretty sure my steelies where 15X7.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
#1272 |
rims change undate
Drag DR21 wrapped in Nitto NeoGen 250/50R15
#1273 |
やりすぎだ~
@GTBaker - Costco has strict policies about fitting certain tires to certain wheels. They mostly do OEM size tires on OEM wheels. However, you can bring it to an independent shop and they will fit your 175/65/15 tire onto your 15x7 wheel. Just call ahead and ask if they'll do it.
The 1010tire site as well as others allow you to choose the tires YOU want, not necessarily being the right fit for your wheel. The wheel/tire package you selected will fit, but Costco will not stray from their rules. OEM tire size in the USA is 185. It must be different in Canada. I believe OEM steelies are 15x5.5. |
#1274 |
The issue I have is I already have the tires(stock tires...only on car 2 months before snow tires). I want to keep the snows on the steelies and put my stock tires on new rims.
With 1010tires wheel configuration tool...you input your car year make & model and it picked the tire size. Which was correct at 175/65/15. Now I find the tires won't fit the rims because the rim is too wide. I don't want to plank down more cash for unneeded tires. I just wish 1010tires would of just came back and said no rims available instead of wasting my time. So if everything people are saying is true...even if I went the wheel and tire package rout the tires were too narrow for the rim. I also hold no fault with Costco as they're just doing their job. I wish more garages were like this. I apologize for straying off thread topic and really should of started another thread. |
#1275 |
やりすぎだ~
Doesn't the picture above say "mounted and balanced"? You'd usually receive it already mounted and balanced. Anyway, this thread should specifically be for posting pics. Moderators, could you please separate these past few posts into a new thread? Much appreciated.
#1276 | |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
One last stray post...
@Yarisugi - the 2012 models come with steelies and 175/65r15 tires standard now.... sucks but meh fuel economy is king. @GtBaker - this must be stressed...RESEARCH RESEARCH RESEARCH before making a purchase. I would seriously think about trying to get the wheels returned or going with a wider tire. the stock wheel size is 15x5 and essentially the stock tire would be stretched and not look or ride correctly. Also : http://www.1010tires.com/About/Fitment-Guarantee The following is from their return policy Quote:
They are not supplying you with tires correct? you wanted to use your o.e.m. tires that you already have. I hate to say it but they don't look responsible in this instance but you could try and fight it anyway.
MicroImageonline forums - Shroomster Xda Forums - Shroomster Androidforums - Shroomster I'm noticing a pattern...... |
#1277 |
Only Happy When it Rains
You will have to call around and find someone who is willing to fit them to that rim, as yarisugi mentioned, some places simply will not do it. Some independent mechanics wouldn't do it either, you really need someone into the import scene and willing to take the risk of stretching tires. Not that it is really that much, but a lot of mechanics think about insurance premiums first, and I can't really blame them, knowing how ridiculous they can be.
Colin Chapman disciple |
#1278 |
1010tires understood what happened and I'm sending them back.
Where in Canada can I buy new rims size 15X5? |
| Post pics of cylinder head (engine) covers here | joelitton | Cosmetic Modifications (Exterior/Interior) | 157 | 08-02-2017 11:36 AM |
| My new 09 yaris! (post bath) | tristan | Photo-Video-Media Gallery | 10 | 10-21-2008 01:23 PM |
