Old 06-01-2007, 08:26 AM   #1
grampi
Drives: Corolla
Please post pics of your Yaris with aftermarket rims here
Also post what type of rims you have (size, brand, style, etc), and which tires you have (size, brand, etc). This will help all us who are contemplating wheels and tires as to which size and style we might like to go with. Thanx.
grampi is offline   Reply With Quote
Old 06-01-2007, 08:38 AM   #2
Good idea for a thread! I'll take the lead
Works Emotion CR Kai 18", 7.5" wide with 42mm offset
Falken FK452 215/35R18
Dropped about 1.5" front and back on TEIN coilovers
Old 06-01-2007, 08:48 AM   #3
spkrman
Drives: 1
20" MB Wheels "spark"
225/30/20 tires
rubs on larger bumps in the front, rubs when heavily weighted down in the rear/big bumps... other than that, can turn to near full lock with 0 rub.
Old 06-01-2007, 08:49 AM   #4
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
Buddy Club P1 Replica (offset unknown, could be 42mm) 15 x 6.5
Michelin New Pilot Preceda 195/55/15
TTE Lowering Springs (30mm front drop, 25mm rear drop)
Old 06-01-2007, 09:15 AM   #5
grampi
Drives: Corolla
echo
Did those 40's throw off your speedo? According to the plus size recommendation on tirerack.com, the correct tire size for a 17" rim is 205/45/17. When doing the math, the 45's also come out to be closer to the overall diameter of the OEM tires and wheels. Just curious. Your's definitely look sweet!
Old 06-01-2007, 09:25 AM   #6
can a moderator stick this topic? I'll be adding mine when I get my rims.
Old 06-01-2007, 09:26 AM   #7
black Ice
Bullshit!
black Ice's Avatar
Drives: Yaris HB 2004
18"x7.5
Ventus 215/35R18
black Ice is offline   Reply With Quote
Old 06-01-2007, 10:40 AM   #8
kimona
kimona's Avatar
Drives: 2014 White VITZ
Thanks. This will be a good thread for anyone searching for just the right wheel for their Yaris.
The most critical spec here would be to always include the offset with your photos.
Old 06-01-2007, 12:05 PM   #9
Astroman
Modded Moderator
Astroman's Avatar
Drag DR-4 Gloss Black alloy wheels with Nitto NeoGen ZR high performance all-season tires. The wheels are 17"x7" with a 40+mm offset and a four bolt pattern, 4x(100/114.3). The wheels are 10 spoke and weigh about 16.5 lbs. The Nitto tires are 215/40 ZR17 NeoGen ZR M+S all season performance tires. No rubbing with full load or on turns. Ride comfort is a tad harsher than the stock 15" but that is to be expected, but handling and grip is the best. Better than falken or daytona tires I have used. I am also running the tires at 52psi, recommended max is 51psi.
Last edited by Astroman; 06-01-2007 at 12:11 PM. Reason: Corrected tire size and offset of rims
Old 06-01-2007, 05:07 PM   #10
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Originally Posted by cdydjded View Post
18" R1 Drift Black Staggard Look 2" lip in front 3" lip in rear. Secret weapon behind the lower front grille.
Secret weapon? That looks like an interfooler with no piping attached. Rims and stance look great though.
Heres mine,
16X7 bronze Heliums 205 50 16 tires and springtech springs. It is about 1/4" lower now. I need to get new pics.
Old 06-01-2007, 05:27 PM   #11
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
1.9 inch drop
15X7 Rota JMAG +40 with 205/50/15 Falken rubber
soon to be +35 in the rear with much more drop
SPONSORED BY
Old 06-01-2007, 07:39 PM   #12
OxyG3nE
Drives: Toyota Yaris 2007
Send a message via AIM to OxyG3nE Send a message via MSN to OxyG3nE
here is mine : DAI alloys 17" with 205/40 tire 42mm offset
OxyG3nE is offline   Reply With Quote
Old 06-01-2007, 07:40 PM   #13
sdmf
Down With the Sickness
sdmf's Avatar
Drives: 2007 yaris liftback
Send a message via AIM to sdmf
TRD Sportivo shocks and springs
Rota Rb 15x 7 +30 offset
Falken Ziex 205/50/15
Strength - Determination - Merciless - Forever
sdmf is offline   Reply With Quote
Old 06-01-2007, 08:13 PM   #14
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Konig Feathers (Gold) 15x6.5 42 offset Michelin Pilot Exaltos PEII 195/55 (Rain)
SSR Comp (Silver) 16x7 40 offset Hoosier A6 205/45 (Dry)
Stock Steelies (black) 15x5.5 (?) Goodyear Eagle LS 185/60 (Hunting Season )
Old 06-01-2007, 08:14 PM   #15
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
better SSR pic
Old 06-01-2007, 09:33 PM   #16
scotttorrez
Drives: 2007 Toyota Yaris
Hey guys, I just put some new wheels on my new Yaris, let me know what you guys think. I just half ass rinsed the car down and its very sunny out, but I think you can still see the picture ok. They are 17" Konig Reasons. I plan to get the Tanabe NF210's and get the windows tinted next.
Before
After
scotttorrez is offline   Reply With Quote
Old 06-01-2007, 10:02 PM   #17
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
There ya go.
17.7-5 42 offset. Falken Hanabis Anodized Bronze. TRD 1.5 drop (trdspark.com)
-- Blen
Old 06-01-2007, 10:53 PM   #18
jookybanana
1NZ-FE all day long
Drives: HS13, NCP91, GE8
Honda Civic SIR wheels 15x6 +45
with Yokohama A032R 205/50/15
Work Emotion CR Kai 18x7.5 +42 front, +36 rear
with Falken FK-452 215/35/18
jookybanana is offline   Reply With Quote
