#19 |
![]() ![]() Drives: 07 BB yaris / 06 Mustang Gt Join Date: Apr 2007
How do i retighten the belt, anyone have picture?? Ty
#20 |
![]() ![]() ![]() ![]() Drives: toyota yaris yrs Join Date: Jun 2007
Ah...get a pry bar or anything solid wedge it between the reinforced part of the alternator and engine mount all you have to do then is pull the pry bar toward you until there's only a hair line of deflection on the belt. You can get someone to tighten the bolt whilst you pull the pry bar towards you.It's easy! don't damage that pipe on the side when you tighten it. Hope this helps.
![]() See the gap between the alternator and down the bottom is the engine mount. Just put a pry bar in between then pull hard on it. |
#21 |
Ty :)
#22 | |
Never again, Dayco. Never again.
#23 |
MetalShark
Drives: 2008 Yaris LB Join Date: Oct 2008
Accessory belt noise
Today I installed a new belt from the Toyota dealer on my '08 Yaris. The Toyota belt has a fuzzy fabric type surface on the Vees side of the belt. My car still makes the bad bearing noises. Using a Harbor Freight stethoscope I checked the water pump bearings, the alternator bearings and the AC clutch hub bearing. They were all loud but the water pump was the worst of the three. It's not leaking......yet. $23.04 delivered from Rockauto.com. Does anyone know where to pick up new bearings for the alternator?
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header. |
| Seat belt buzzer is silenced | billk | General Yaris / Vitz Discussion | 48 | 10-30-2013 09:58 AM |
| new serpentine belt | dferguson2 | DIY / Maintenance / Service | 1 | 06-30-2012 08:07 PM |
| The Accessory belt? | N9QGS | DIY / Maintenance / Service | 4 | 02-12-2009 11:05 PM |
| Rough Idle in drive | toyoman | NY / NJ/ CT / PA | 8 | 04-22-2007 03:40 AM |
