Question on brake bleeding...
I am familiar with brake bleeding, how to do it and such...my question is since I had to replace a rear, brake cylinder on a drum brake yesterday due to blowing it out, should I have to bleed the entire system?
I naturally bled that side (rear driver side), but I know the order is farthest to closest to the master cylinder. I replaced the front pads, rotors, drums and shoes and I will say the brakes feel a bit squishy and not even as good as before I did the work. When I put on stainless lines and replaced the brake fluid a month ago, the feel was much better than it is now. I think I need to bleed the entire system from furthest to closest again as it has to have air in the line somewhere. Do you think? Any other thoughts? |
You should only have to bleed the wheel cylinder you replaced.
I would do it again and see if you find any air. Perhaps though from the work you did previously there is air someplace. You might try a total four wheel bleed. If you get air....you found the problem
#3 | |
![]() ![]() Drives: Yaris 1.33 litre 2011 Join Date: Dec 2009
Regards Geoff Peace. |
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
why are you bleeding it on the master cylinder end? the air inside the lines will still be there if ever. bleed it on the end of the line near the brake cylinder/wheel you serivced, do what 's called "pump-pump-pump-stay".
HTH. |
#5 | |
old style
You can still bleed them the old style as long as you know what you're doing and have good communications between yourself and the fellow doing the pedal pumping. The way you would move the master piston too far is if you keep pumping while the bleed valve is still partially opened, good communication and one pump and hold at a time works pretty good. Done that many times in all my cars, my 2 cents on this......
Ok ok...just getting back here on this.
I bled them just using the "gravity" method....slow and steady wins the race. Firstly, I am not bleeding from the master, but from the wheel end of each line. Secondly, I went back and started from furthest to shortest from MC and did a gravity bleed by just letting the fluid drip and watching for bubbles. I changed the fluid recently and noticed it is all nice and clear and has no bubbles at all. I also adjusted my e-brake a bit more so it has only one click to engage now. Now...with the stainless lines from MI, new drilled and slotted rotors, Hawk pads, R1 shoes and drums, the brakes are firm and make braking the Yaris enjoyable again. Thanks for all the help and suggestions. |
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 08:50 AM |
| red hot brake shoes | tommo | DIY / Maintenance / Service | 1 | 08-31-2011 07:34 PM |
| another brake question | swidd | DIY / Maintenance / Service | 10 | 06-20-2010 05:51 PM |
| brake question | stuffy | DIY / Maintenance / Service | 12 | 06-18-2010 05:04 PM |
| Help Needed - Brake Light Question | *MAD DOG* | Cosmetic Modifications (Exterior/Interior) | 21 | 02-08-2009 05:32 AM |
