Old 04-01-2013, 08:54 AM   #1
Yarflana
Drives: 2008 Base Model
Question on brake bleeding...
I am familiar with brake bleeding, how to do it and such...my question is since I had to replace a rear, brake cylinder on a drum brake yesterday due to blowing it out, should I have to bleed the entire system?
I naturally bled that side (rear driver side), but I know the order is farthest to closest to the master cylinder.
I replaced the front pads, rotors, drums and shoes and I will say the brakes feel a bit squishy and not even as good as before I did the work. When I put on stainless lines and replaced the brake fluid a month ago, the feel was much better than it is now.
I think I need to bleed the entire system from furthest to closest again as it has to have air in the line somewhere.
Do you think? Any other thoughts?
Yarflana is offline   Reply With Quote
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
another brake question swidd DIY / Maintenance / Service 10 06-20-2010 05:51 PM
brake question stuffy DIY / Maintenance / Service 12 06-18-2010 05:04 PM
Help Needed - Brake Light Question *MAD DOG* Cosmetic Modifications (Exterior/Interior) 21 02-08-2009 05:32 AM
