Old 04-07-2013, 02:02 PM   #1
lamadoo
Drives: 2007 Yaris 3door white
Spark plug Question please :)
Hi guys I have a 2nz-FE 1.3lt NCP90R
Do i have to Gap the spark plug NGK BKR5EYA11 to 0.043 or is it pre-gapped already? I can't find an affordable Spark plug Metric tool in my area (20 dollars at minimum)
Do you think it is more worth it to wait and invest in the super pricey version?
NGK Iridium IX BKR5EIX-11 ?
Thanks
lamadoo is offline   Reply With Quote
Old 04-07-2013, 02:23 PM   #2
Geoff Peace
Drives: Yaris 1.33 litre 2011
Thanks
BKR5EY11 will be pre gapped to 1.1 mm. (43 thou.)
All you need to gap the plugs is a set of feeler gauges, surely not $20.
Regards Geoff Peace.
Geoff Peace is offline   Reply With Quote
Old 04-07-2013, 02:32 PM   #3
Geoff Peace
Sorry! I forgot the second part of your post. I fitted iridium plugs to my car about a year ago well worth it in my opinion. Around 8% increase in m.p.g. and smoother running.
Old 04-07-2013, 02:36 PM   #4
lamadoo
oOOo thanks Geoff, its a perfect fit .
My yaris needs it at 1.1mm, no need for a guage feeler
How much do feelers costs?
The cheapest auto shop here sells them at 13 to 38 dollars and i don't think they can measure up to 1.1mm
http://www.supercheapauto.com.au/sea...k.x=0&look.y=0
Old 04-07-2013, 03:59 PM   #5
bcat37645
Drives: 2dr Hatchback
I changed plugs today on my 2009. It had NGK IFR5A11 (iridium long life) from the factory. My mi was 97000. I put Denso SK16R11 (iridium long life) back in. It's my understanding they're essentially identical. The change out was simple and I torqued to 15 ft lbs. I would go with iridium plugs in this engine and do not gap them...they're pre gapped and fragile. Good luck.
bcat37645 is offline   Reply With Quote
Old 04-07-2013, 05:25 PM   #6
mf4361
Drives: Yaris Sedan
I agreed that Iridium IX plugs are pregapped and should not be gapped according to NGK. Iridium tip is extremely fragile and even small impact will break it.
I put 4 of them into my 1NZFE two weeks ago and it runs great and quiet.
mf4361 is offline   Reply With Quote
Old 04-08-2013, 12:12 PM   #7
esse10
Drives: 2009 yaris 2 door
plugs
I took my original one's(55k miles) out last week and they were right at around .038-39 gap, put anti-seize on the threads and put back in. I'll probably replace them around 100k miles or so. Glad I took them out cause they were real tight, about 30-35 footpounds from the factory. to answer your question-no you shouldn't have to gap iridium plugs, I believe the gap range is .038-.043
esse10 is offline   Reply With Quote
Old 04-08-2013, 12:37 PM   #8
lamadoo
Thanks for help guys, just changed my spark plugs today. It had the DENSO copper spark plugs that toyota serviced for its previous owner.
My service manual says to change it every 40km. My yaris is 80km now, last changed 40km ago by toyota and its previous owner.
The old spark plugs were about 1.4-1.5mm gapped from its original 1.1 and quite blackened, i wouldn't advise on following the Australian Service Manual of changing the plugs every 40km using its oem NGK (non iridium) and Denso like it says in the manual..
Old 04-08-2013, 12:55 PM   #9
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
I use one of these devices that cost $2 at your local auto parts store.
Have Yaris will travel..
Spark Plug Problem TickleTimeTim DIY / Maintenance / Service 15 09-07-2013 10:18 AM
How hard I should try to remove spark plug mf4361 DIY / Maintenance / Service 24 03-30-2013 03:07 PM
Spark plug change . Dc1011 DIY / Maintenance / Service 2 01-29-2012 02:55 PM
Do we need to regap our spark plug? marcus DIY / Maintenance / Service 2 08-31-2010 11:53 PM
spark plug gap Hard_Yaris DIY / Maintenance / Service 2 06-10-2010 06:23 PM
