Old 03-25-2013, 12:04 AM   #1
mf4361
Drives: Yaris Sedan
How hard I should try to remove spark plug
I am trying to change out my spark plug, as mine has 126000km on it and its still the same one out from factory.
I was trying to unscrew it by a crappy (Canadian) tire spark plug remover (very low quality), but i can't get it loose even by forcing it. Obviously I don't want to really force it out as its possible that it seized up. My next step is to break it loose by a ratchet/socket (and so I got a 6" extension bar). My question is, how hard should I try undoing it before I take it to a garage for a proper seized-up plugs removal?
Sorry if its a stupid question, I am really new to DIY vehicle maintenance.
Thanks all!
mf4361 is offline   Reply With Quote
Old 03-25-2013, 02:50 AM   #2
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
It's important to use the right tool.A ratchet with an extension plus a spark plug remover socket. Turn it anti clockwise/ counter clockwise until the plugs loosens up. I would say a firm turn on the ratchet should do the job..
WARNING!! disconnect your negative battery terminal first just in case.
Old 03-25-2013, 06:02 PM   #3
bronsin
bronsin's Avatar
Not removing the sparkplugs for a long time can lead to their seizing for various reasons. A brown residue will build up on the threads. If that is the cause forcing the plug out will PROBABLY not take the threads with it.
On the other hand....
If the threads in the head come out with the plugs you are SCREWED! I would wait for people to check in here whether or not the head will have to come off to repair them.
If not...then you just have to have the car towed to a mechanic and pay $$$ to fix it.
With electronic ignition and fuel injection sparkplug life is practically indefinate. If you chose to leave the plug in there Im thinking thats a good choice if you plan to keep the car only a couple more years.
You could put the plugs back in, take it to a mechanic and innocently ask to have the plugs changed. If he strips it its his dime.
Or he could just pretend he did it...
My advice:
Put the other plugs back in and drive it.
Take it to a mechanic.
Good luck and tell us what happens!
Old 03-25-2013, 06:27 PM   #4
That is a bad strategy. Use GOOD tools, and have an extension on hand. My plugs "break free" when I take them out. After that first pop, they come out easy.
Old 03-25-2013, 11:04 PM   #5
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
If you're having that much trouble getting one out, it would be way better to have a professional do it for reasons mentioned above. The plug can break. This is why mechanics recommend pulling them every 60k or because they like to weld themselves to the head.
Old 03-25-2013, 11:29 PM   #6
alanwagen
stone cold
The engine has to be cold cold cold as with thermal expansion, the heads will hold the plugs when they are warm.
Old 03-26-2013, 12:46 AM   #7
edmscan
edmscan's Avatar
Drives: 2020 Corolla
I had the same problem with my 87 Accord. I couldn't get the plugs out .. and I bent the Canadian Tire spark plug removal tool as well (yes it does really suck). I actually had the mechanic at Canadian Tire remove / reinstall my spark plugs for me. They did it for free ... must have been a good day as really I pretty much hate Canadian Tire.
I sold the Accord to an auto wrecker a week later (this is when I bought my Yaris). Not my problem now.
edmscan is offline   Reply With Quote
Old 03-26-2013, 07:03 AM   #8
bronsin
bronsin's Avatar
I have removed stuck plugs by removing them with the engine HOT after trying it COLD.
Cold is the default for plug removal.
But sometimes you try it different.
Old 03-27-2013, 01:42 AM   #9
mf4361
Drives: Yaris Sedan
Thanks for all the advice! I will try next time when I have time.
Old 03-27-2013, 07:24 AM   #10
bronsin
bronsin's Avatar
When you try it with a beefier socket arrangement try it with the engine cold first.
If it wont budge warm the engine up and try it.
Ive had time to rethink my advice on this. I suspect you just have a stuck plug that will come out okay once you put the beef to it.
But I wont be able to sleep until I hear what happens!
Old 03-27-2013, 10:06 AM   #11
mf4361
Drives: Yaris Sedan
Ok :D standard practice first. lucky here in my town is still about 4 degree above zero so its still rather cold for a spark plug change
Old 03-27-2013, 12:15 PM   #12
Yaristeve
Drives: 3-door hatch
I had to google this "crappy (Canadian) tire spark plug remover" to see what you guys are talking about. Throw it away!
Get a good spark plug socket for your ratchet. Although you can use a standard socket (save $$$), spark plug sockets come with a little rubber donut insert to help you from cracking the insulator when installing a new plug. Plus the donut helps hold the spark plug in the socket as you lowering it into the spark plug well; that way your plug won't fall in and possible change the gap.
Old 03-27-2013, 12:44 PM   #13
esse10
Drives: 2009 yaris 2 door
plugs
If you only replace the plugs once every 100k miles than yea it would be a good Idea to remove them around 50k miles , put anti-seize compound on the threads, check the gap and re-install. You'll have no problem taking them loose the next time at 100k miles.
Old 03-27-2013, 03:16 PM   #14
bronsin
bronsin's Avatar
Here is a quick tutorial for removing spark plugs from the Yaris (and ECHO and many others) Obviously meant for people who havnt done this before.
The picture is the tool you want. A 3/8 inch drive ratchet, a six inch extension in 3/8 inch drive and a 5/8 inch sparkplug socket also 3/8 inch drive.
The six inch extension is Shoo Gooed to the sparkplug socket. It is NOT shoo glued to the ratchet! The socket cant be removed from the extension making it a tool to remove sparkplugs only.
The 5/8 sparkplug socket has a rubber insert to hold the sparkplug while you unscrew and lift out the origional plug and to hold the replacement plug while you lower it in place.
The six inch extension is shoo glued to the socket to prevent the socket from pulling off the extension when removing it from the new sparkplug.
When installing the new sparkplug (or reinstalling the old one) spray the rubber insert with WD40. This will allow the insert to hold the plug while lowering it into place and allows to plug to easily slip out of the socket once it is screwed and torqued into the head.
The reason for the shoo goo and WD40 is the extension will pull off the socket and stay down in the cylinder head when installling the new plug and tryiong to get the tool out of the hole.
Any Questions?
Old 03-27-2013, 03:51 PM   #15
esse10
tape
another thing that works pretty good is using black electrical tape to keep the socket attached to the extension and also you can use some tape at the end of the socket to temporarily hold the new spark plug in the socket as you put it back in the hole. Just lower it down slow and get a few threads started then pull out the extension & socket, then move the end tape out of the way and use the same socket/extension & ratchet & regularly tighten plug snug tight. then you can torque as required. I can post a picture of this if anybody wishes, I have been doing that method on all my cars for years now. Don't use the socket that has the rubber o-ring inside used to remove the spark plug because sometimes that rubber o-ring comes off and stays stuck deep in the hole and now you would be doing wasted work trying to fish that out of the hole. & I don't like putting wd40 on my new plugs either, just regular dialectric grease to keep moisture away.
Old 03-29-2013, 05:04 PM   #16
mf4361
Drives: Yaris Sedan
I finally got a chance this afternoon to change the plugs out. I used a 5/8" spark plug socket, 6" extension and a ratchet. It took a little more force than I expected to get it out. (So first thought is it might have seized up) But as suggested above a firm turn on the ratchet break it loose and it got out easily.
The old plugs are actually still in pretty good shape after 126000km (and they drove well) but its good preventive maintenance so I don't get stranded on the roadside when the time comes
After installing the new plugs, engine starts better, the starter clicks 2-3 times and it starts (compared to 4-5 clicks before). I don't see a big improvement in Performance/economy. However, Idle seems to be quieter and at high rev (>4500) it definitely sounded smoother.
Thanks for all your help and advice!!
https://www.dropbox.com/s/uyvsib1ctv...329_164906.jpg
Old 03-30-2013, 07:18 AM   #17
bronsin
bronsin's Avatar
Awesome glad you endevoured to persevere and you had no trouble!
Old 03-30-2013, 09:16 AM   #18
junorico24
junorico24's Avatar
Next is to change the transmission fluid and that would improve your shifting and ride a bit.
Get yourself a long clear tube and a bottle. Cut the bottle in half, drill a hole on the cap of the bottle put the clear hose through it. This is to get the fluid into your tranny hole.
NEXT undo the fill plug first, very important.Then the bottom drain plug is next.
By the way do it on a level area. Let the fluid drip out onto a catch pan, after it empties completely put the plug back on snug. Then fill it up by using your DIY half bottle with a clear tube.Slide this apparatus into the fill hole.
Then all you have to do is get 2 quarts of synthetic manual transmission fluid.Pour it into the bottle this will go down onto the clear tube and into the fill hole.Fill it up until it drips out. Let it level out then put the fill plug back on and torque it snug.
Spark plugs suggestion walt101786 DIY / Maintenance / Service 29 03-05-2023 09:06 PM
Spark plug torque Geoff Peace DIY / Maintenance / Service 11 05-05-2021 02:48 PM
Spark Plug ubospawis Middle East 11 09-01-2010 08:55 AM
Do we need to regap our spark plug? marcus DIY / Maintenance / Service 2 08-31-2010 10:53 PM
How hard is it to remove side skirts and front lip on 08 sports package? dono37 Cosmetic Modifications (Exterior/Interior) 15 09-26-2007 05:28 PM
