Old 04-29-2013, 06:53 PM   #1
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
a hum noise in 5th
a hum noise in 5th around 80km up to 110km its on and off as u drive out of gear it goes away so thinking drive line but cant find anything wrong with car ...any ideas would help, car drives fine .
Old 04-29-2013, 11:36 PM   #2
Freestylin
Freestylin's Avatar
Drives: 09 Blizzard Pearl RS LB
Is the noise coming from the front? If so, did you check your front wheel bearing? Jack up the car and try to see if there is any play when you try to rock the wheel vertically. If it feels loose, then your bearing may have went bad.
Do you have uneven wear in your tires? This could also cause the noise..
Freestylin is offline   Reply With Quote
Old 04-30-2013, 02:28 PM   #3
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
all in that area is fine only does it it 5th gear under load
Old 04-30-2013, 04:06 PM   #4
B2FiNiTY
B2FiNiTY's Avatar
Drives: Prius C
wheel bearing or transmission bearing.
is it high pitched?
B2FiNiTY is offline   Reply With Quote
Old 04-30-2013, 05:16 PM   #5
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
is it high pitched?
low ...not a pitch just a hum on and off , and no not a wheel bearing like i said only under load when in gear, this would make it drive train related. Our cars dont have pilot bearing if i remember correctly. Its not loud have to listen for it , can even feel it too. Like i said had/have looked over the car and cant find nothing wrong ..change diff fluid and no change...only think i can think of its the 5th gear ...and to just live with it as it does not effect the car in anyway.
Just was wandering if anyone had or has this problem if u could even call it a problem.
Old 04-30-2013, 11:56 PM   #6
Freestylin
Freestylin's Avatar
I don't have this issue with my car. How loud is the sound?
“On a given day, a given circumstance, you think you have a limit. And you then go for this limit and you touch this limit, and you think, 'Okay, this is the limit'. And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high.” ― Ayrton Senna
Old 05-01-2013, 07:07 PM   #7
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
just kind of there , but with windows down or radio up u dont really hear it ...sometimes i hate knowing how to fix cars lol cos i always listen or hear what others may not..haha funny is just cant locate it it could be the trans bearing at the end by the fith gear ....i just put my volume up higher lol
Old 05-04-2013, 12:18 AM   #8
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
sounds like normal tire noise to me. Sometimes when you hit just the right type of road and speed, they get louder due to certain harmonics.
Colin Chapman disciple
Compilation of Yaris TSBs eTiMaGo DIY / Maintenance / Service 72 07-04-2024 10:36 AM
Help With Reverse Noise???? JoshW DIY / Maintenance / Service 0 09-09-2011 12:27 PM
2010 12th Touge.ca Track lapping - September 5th Mosport DDT Lapping event!! Touge.ca Canada 1 08-24-2010 03:01 AM
July 5th Mosport DDT lapping event, 1:00-5:00pm! 2009-7th Touge.ca lapping event! Touge.ca Canada 0 06-04-2009 06:47 AM
Radio noise.. need help TinyGiant In Car Entertainment + Electronics (audio / video / alarm) 13 12-06-2008 04:21 PM
