Old 04-29-2013, 11:36 PM   #2
Freestylin
Freestylin's Avatar
Drives: 09 Blizzard Pearl RS LB
Is the noise coming from the front? If so, did you check your front wheel bearing? Jack up the car and try to see if there is any play when you try to rock the wheel vertically. If it feels loose, then your bearing may have went bad.
Do you have uneven wear in your tires? This could also cause the noise..
Freestylin is offline   Reply With Quote
Compilation of Yaris TSBs eTiMaGo DIY / Maintenance / Service 72 07-04-2024 10:36 AM
Help With Reverse Noise???? JoshW DIY / Maintenance / Service 0 09-09-2011 12:27 PM
2010 12th Touge.ca Track lapping - September 5th Mosport DDT Lapping event!! Touge.ca Canada 1 08-24-2010 03:01 AM
July 5th Mosport DDT lapping event, 1:00-5:00pm! 2009-7th Touge.ca lapping event! Touge.ca Canada 0 06-04-2009 06:47 AM
Radio noise.. need help TinyGiant In Car Entertainment + Electronics (audio / video / alarm) 13 12-06-2008 04:21 PM
