Old 05-05-2013, 10:54 PM   #19
California 1976 and up.
Old 05-05-2013, 10:57 PM   #20
kou
Drives: 08 lb
Originally Posted by pimp my yaris View Post
I am going to test in the next week. First test ever after 4 years. My turbo is still attached to my lower compression built motor. I opened the wastegate and attached my k&n filter and mass air directly to my throttle body bypassing the turbo. I put back in the stock injectors and lowered my fuel pressure back to stock and dissconnected the vac line to my regulator. Also installed the fic bypass plug. I installed a converter on my car. So far I only have a evap. Emissions code because I lost the purge solinoid under the hood. I have it on order at the toyota dealer.
What a pain in the ass. Next time I will register this thing in some far away place or get a older car to build.
Be carefull you dont over spin that turbo with you wastgate stuck open.
Old 05-06-2013, 12:12 PM   #21
Focus_Sh1ft
Focus_Sh1ft's Avatar
Drives: 08 Yaris Turbo; 06 tC Turbo
Won't be a problem with it stuck open. If it were stuck closed, however...
Pimp, does Illinois have visual inspection too or just OBD? It looks like you're going way overboard with prepping for inspection. What codes were you throwing with your current setup?
Focus_Sh1ft is offline   Reply With Quote
Old 05-06-2013, 05:17 PM   #22
Jerkratt
Jerkratt's Avatar
havent really been reading every post but im running blitz SC, AEM FiC no cats ect ect and i pass just fine with OBD2. i throw no codes unless i use my WOT box (cuts ignition so i would hope it throws a code)
"It hurts more when its wet"
Old 05-07-2013, 02:51 AM   #23
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
Originally Posted by FHT_Racing View Post
So you have no catalytic converters at all between the two O2 sensors?
Thanks,
Andrew
That's correct.
Old 05-07-2013, 10:04 AM   #24
Jerkratt
Jerkratt's Avatar
Nether do I.. I have three resonators
Old 05-07-2013, 05:09 PM   #25
FHT_Racing
Drives: 2009 Toyota Yaris 3-Door
I'm guessing everyone without cats is using a defouler or has their 2nd O2 sensor spaced out from the exhaust flow then?
FHT_Racing is offline   Reply With Quote
Old 05-07-2013, 05:19 PM   #26
Jerkratt
Jerkratt's Avatar
I am yea
Old 05-09-2013, 09:43 PM   #27
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
Well I got all my emission parts on the car but I am still getting a po420 cat. efficiency code. My cat converter is on the pipe with clamps. I think I will need to get it welded on to eliminate all leaks. I hope that works. Also my evap. Monitor is showing incomplete. I think I will need a cold start up in order for it to test. I have added a return line with a external regulator. I hope it passes the test. Pain in the ass.
pimp my yaris is offline   Reply With Quote
Old 05-09-2013, 10:15 PM   #28
kou
Drives: 08 lb
if its an $80 dollar magnaflow highflow cat like I have on mine they only keep the cel off for 6months or so.
Old 05-22-2013, 11:12 PM   #29
pimp my yaris
C'est la vie
Well I finally passed my emissions test yesterday. I had to have a new cat. Converter installed to clear my p0420 code. 140$. Today I reinstalled my wideband and hooked the turbo back up. I left the factory o2 sensors attached to see if I could keep the light off with the turbo working at 12-13 psi. Before all this crap started I was running 13-1 afr with the factory o2 sensors disconnected at a steady cruise and it would richen up to 11 to 11.5 to 1 afr when at full throttle.
Now with the factory fuel trim working Im at 14-1 afr at all times except for full throttle where Im still in the 11-1 range.
This does wory me when at partial throttle and in the boost being so lean. I am not sure how this will work out in the long run. But honestly the car never ran better. It feels just like a factory turbo car. Runs perfectly, just like stock only much more power. The check engine light is off. I checked long term fuel trim and its at -18%. So the factory computer is certainly leaning out my tune from the FIC. Except at full throttle.
On a side note with the FIC hooked up previously I was never able to go over 5700rpm. I thought their was a problem with my FIC. Now with the o2 sensors hooked up. I am reaching the full 6300 redline with no problems.
