Old 04-30-2013, 06:02 PM   #1
FHT_Racing
Drives: 2009 Toyota Yaris 3-Door
BOOSTED AND PASSING OBD2 INSPECTION?
JUST BECAUSE I'M CURIOUS, WHO ALL IS PASSING OBD2 EMISSIONS TESTING AND BOOSTED? NO CHECK ENGINE LIGHTS?
THANKS,
ANDREW
FHT_Racing is offline   Reply With Quote
Old 05-01-2013, 04:44 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
First of all...lay off the all caps...please.
Not many if any folks are actually not throwing at least one code with a turbo setup while still using the stock ECU. Have heard of folks using an SC without codes. Which are you looking for info on?
Old 05-01-2013, 04:55 PM   #3
FHT_Racing
Apologize about the caps. We use all caps at work...
I'm just interested to see what people are doing to get rid of the O2 code if they are catless. Especially folks that are turbo WITHOUT going standalone.
Thanks,
Andrew
Old 05-01-2013, 06:31 PM   #4
If your motor is tuned properly, you shouldn't have check engine lights or codes.
If you've deleted your cats, you won't pass a sniff test no matter what.
Old 05-01-2013, 06:51 PM   #5
FHT_Racing
We don't have sniff tests in my county if the car is OBD2. Just plug into the computer.
No check engine light/codes, it will pass :) How is everyone not getting a CEL when turbo/straight pipe/catless on stock computer?
Old 05-02-2013, 01:16 AM   #6
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
I've got a Blitz, AFe intake, DC header, midpipe (cat delete), and HK axle back and I don't throw any codes. All that stuff is on a stock ECU. I'm sure it would fail emission testing but AL doesn't have any of that stuff anyway.
Old 05-02-2013, 09:22 AM   #7
TOLMACH
Drives: soarer
even in case of no CEL?
(which is my case now)
Old 05-02-2013, 11:13 AM   #8
kou
Drives: 08 lb
^^ If you have no codes and canada does not do sniff test on exhaust you will pass inspection without a cat installed. If they do sniff test you will fail if you have no cat.
Old 05-02-2013, 11:40 AM   #9
FHT_Racing
So you have no catalytic converters at all between the two O2 sensors?
Thanks,
Andrew
Old 05-03-2013, 11:37 AM   #10
Focus_Sh1ft
Focus_Sh1ft's Avatar
I've been wondering this for awhile, since you're 'supposedly' allowed one unready status. If you have both O2 sensors in, only the catalytic converter efficiency threshold would show up as unready...
If that's the case, I need to go get inspected.
Old 05-03-2013, 11:42 AM   #11
kou
Drives: 08 lb
If you know someone with an OBD scanner that tells you if your emmisions ready and your in the green you should have no issues.
Old 05-03-2013, 11:48 AM   #12
kou
Drives: 08 lb
Oh and if you dont have a cat or something that looks like a cat in place you may have problems if they get the mirror out to look under the car. Take it to a private shop may be better as long as OBD is clear they might not mind as much if you have no cat.
Old 05-03-2013, 03:22 PM   #13
FHT_Racing
I work at Toyota and have no problem getting the car inspected as far as visual goes, but i'm looking for an answer for the CEL question...
Who is running no cats on stock ECU without a CEL? Possibly using defoulers?
Thanks,
Andrew
Old 05-03-2013, 03:59 PM   #14
kou
Drives: 08 lb
^^^ Yes you can run a o2 sensor extender/adapter to keep the cel off.
Old 05-03-2013, 04:28 PM   #15
Like this one, which is proven and very nice quality:
http://shop.microimageonline.com/O2-...r-o2-af-01.htm
Old 05-03-2013, 04:34 PM   #16
TOLMACH
Drives: soarer
thanks
Old 05-03-2013, 05:26 PM   #17
FHT_Racing
I'll take it! :)
Is your turbo manifold ok compliant with AC lines? If so, I'll take one of those too!
Thanks,
Andrew
Old 05-03-2013, 10:19 PM   #18
^ Yes!
And remember you owe me a bunch of interior pieces? (for money)
