#19 |
California 1976 and up.
#20 | |
#21 | |
![]() ![]() ![]() ![]() Drives: 08 Yaris Turbo; 06 tC Turbo Join Date: Jan 2010
![]() Pimp, does Illinois have visual inspection too or just OBD? It looks like you're going way overboard with prepping for inspection. What codes were you throwing with your current setup? |
#22 |
![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Liftback S (RIP 07) Join Date: Apr 2007
havent really been reading every post but im running blitz SC, AEM FiC no cats ect ect and i pass just fine with OBD2. i throw no codes unless i use my WOT box (cuts ignition so i would hope it throws a code)
"It hurts more when its wet" |
#23 |
What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
That's correct.
![]() My Nissan Hardbody (D21) 4x4 build log Check out my YouTube channel (mostly shooting) - http://www.youtube.com/user/47MasoN47 |
#24 |
Nether do I.. I have three resonators
#25 |
![]() ![]() Drives: 2009 Toyota Yaris 3-Door Join Date: Jan 2013
I'm guessing everyone without cats is using a defouler or has their 2nd O2 sensor spaced out from the exhaust flow then?
#26 |
I am yea
#27 |
C'est la vie
Drives: 2009 2 door hatchback Join Date: Aug 2009
Well I got all my emission parts on the car but I am still getting a po420 cat. efficiency code. My cat converter is on the pipe with clamps. I think I will need to get it welded on to eliminate all leaks. I hope that works. Also my evap. Monitor is showing incomplete. I think I will need a cold start up in order for it to test. I have added a return line with a external regulator. I hope it passes the test. Pain in the ass.
#28 |
if its an $80 dollar magnaflow highflow cat like I have on mine they only keep the cel off for 6months or so.
#29 |
C'est la vie
Well I finally passed my emissions test yesterday. I had to have a new cat. Converter installed to clear my p0420 code. 140$. Today I reinstalled my wideband and hooked the turbo back up. I left the factory o2 sensors attached to see if I could keep the light off with the turbo working at 12-13 psi. Before all this crap started I was running 13-1 afr with the factory o2 sensors disconnected at a steady cruise and it would richen up to 11 to 11.5 to 1 afr when at full throttle.
Now with the factory fuel trim working Im at 14-1 afr at all times except for full throttle where Im still in the 11-1 range. This does wory me when at partial throttle and in the boost being so lean. I am not sure how this will work out in the long run. But honestly the car never ran better. It feels just like a factory turbo car. Runs perfectly, just like stock only much more power. The check engine light is off. I checked long term fuel trim and its at -18%. So the factory computer is certainly leaning out my tune from the FIC. Except at full throttle. On a side note with the FIC hooked up previously I was never able to go over 5700rpm. I thought their was a problem with my FIC. Now with the o2 sensors hooked up. I am reaching the full 6300 redline with no problems. |
