Old 05-09-2013, 07:28 PM   #1
kou
Drives: 08 lb
AEM FIC tuning tips
Thought I would start a thread so anyone who has an AEM FIC installed can share what they know.
I will start with what I have, I am running a customized Zage turbo kit running around 8psi at sea level. My car right now is running like it should from the factory I am running the z107 firmware and my injector response time is set to 810us on stock injectors and your MAF clamp should be set at 4.95v here is my tune so far as I may need to add some fuel up top but I haven't been there to find out yet,this is what it looks like in the program.
Old 05-09-2013, 07:37 PM   #2
TOLMACH
Drives: soarer
WOW!!
Thanks, man
Old 05-09-2013, 07:59 PM   #3
kou
Drives: 08 lb
And here is some stock fuel trim info.
AFR-fuel trim
11:0-39
11:3-35
11:5-34
11:7-32
11:9-30
12:0-28
12:2-25
12:6-23
12:8-20
13:0-18
13:2-17
13:5-15
13:7-12
14:0-10
14:3-9
14:7-6
14:9-1
15:2-0
Old 05-09-2013, 08:00 PM   #4
kou
Drives: 08 lb
Originally Posted by TOLMACH View Post
WOW!!
Thanks, man
You are welcome
Old 05-09-2013, 08:08 PM   #5
Focus_Sh1ft
Focus_Sh1ft's Avatar
Good information, thanks. I have nothing to contribute that you haven't already covered lol.
Old 05-09-2013, 08:33 PM   #6
kou
Drives: 08 lb
^ Thank you for earlier I put 6's in all my 0's on the fuel map and it really cleaned everything up nice after I fixed my MAF clamp.
Old 05-09-2013, 08:37 PM   #7
yariSB86
yariSB86's Avatar
Drives: 07 Bayou Blue Yaris LB
If you guys right click the Fuel map window there is an option to change the fuel injector size. has anyone messed with this?
BTW Thanks Kou
_______________________________________________
yariSB86 is offline   Reply With Quote
Old 05-09-2013, 08:42 PM   #8
kou
Drives: 08 lb
Not me yet. But i would think you would need a tune that is working with stock injectors then it would be easier to increase the size.
Old 05-09-2013, 08:49 PM   #9
yariSB86
yariSB86's Avatar
I'm not using stock injectors. I've tried several things to get my car to idle right.
With how i have it setup now, I'm running 14.7s AFR but the car still bogs down to 500-600 rpms and stalls when the engine is warm.
I'm running the 1zz injectors, I've tried increasing and decreasing the response timing, I've tried to increase the injector size on the fuel map, I've tried negative numbers in the fuel map (reduces the amount of fuel used by injectors?), nothing i do gets the car to idle like stock...
Old 05-09-2013, 08:54 PM   #10
kou
Drives: 08 lb
I can only suggest you open a new file copy my tune put it on the FIC see how it idles then adjust for the fuel injectors. You can always go back to your original file.
Old 05-09-2013, 09:36 PM   #11
yariSB86
yariSB86's Avatar
@Kou - Thanks tons man!
Started the car, letting it warm up now. Everything looking great so far. Once its warm I'm going to drive it around for a bit. Can't wait!
Old 05-09-2013, 09:39 PM   #12
kou
Drives: 08 lb
Cool. Try it out see what happens.
Old 05-09-2013, 09:42 PM   #13
yariSB86
yariSB86's Avatar
AHHHHH!
still stalls once warm....I don't get it.
Old 05-09-2013, 09:44 PM   #14
yariSB86
yariSB86's Avatar
With the FIC and the Boomslang harness, how do i connect the bypass harness?
EDIT: This is crazy, car idles great, then out of nowhere RPMs fall below 600 and the car stalls...any ideas guys?
Old 05-09-2013, 09:55 PM   #15
kou
Drives: 08 lb
connect the bypass harness into the boomslang harness
Old 05-09-2013, 09:59 PM   #16
kou
Drives: 08 lb
did you adjust for injector size. how was it to drive with the tune I gave you? If you let it idle until its warm will it stall or is it when you are coming to a stop?
Old 05-09-2013, 10:08 PM   #17
kou
Drives: 08 lb
Do you have the stock throttle body? do you have a vacuum leak?
Old 05-09-2013, 10:18 PM   #18
yariSB86
yariSB86's Avatar
i did adjust for injector size, i made the number bigger (i think lol)
AEM FIC fight for turbo!!! thatbryanguy Forced Induction Forum 135 08-14-2015 08:22 PM
FS: AEM FIC + Wiring Harness Boomslang djgab101 Items for Sale by private party 18 12-06-2013 03:36 AM
FS: Zage Turbo kit, AEM FIC with Pnp Harness djgab101 Items for Sale by private party 32 04-11-2013 10:42 AM
AEM FIC tuning experience thatbryanguy Performance Modifications 0 09-03-2012 01:29 PM
AEM FIC Tuning Scubaru Steve Forced Induction Forum 37 03-06-2011 11:16 PM
