Old 01-19-2011, 10:41 PM   #1
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
AEM FIC Tuning
anyone know what the voltage - afr table is for the stock echo/yaris o2 sensor?
also how to switch over the controller to sent out a signal or the stock computer to read so i can tune open loop?
Scubaru Steve is offline   Reply With Quote
Old 01-20-2011, 02:08 AM   #2
Focus_Sh1ft
Focus_Sh1ft's Avatar
1). I don't think anyone has even set up the O2 signal properly on the 1NZ. I've tried all the methods AEM recommends and had no luck.
2). If you're asking how the FIC can be set up to only send signals during open loop that's easy. You would just edit the fuel map only where the car enters open loop.
If you're asking how to send a signal to the ECU to switch to open loop then that is impossible. Well, not impossible but no one has figured out a way to do so.
Open loop tuning... Do it
Your welcome to try and solve some of the issues I mentioned though. Personally, I went with what is known to work rather than being a perfectionist.
Old 01-20-2011, 12:03 PM   #3
Scubaru Steve
Awesome!
the reason im asking these questions is that im not used to tuning piggy backs, my wrx i can just hook in my laptop and open source tune my ecu, i have found no product to do it for the 1nzfe.
so now with this piggy back i get to try to tune.
i have been reading the book and i see that there is an afr-voltage table.
there is also something in there stating that you can install a resistor in the wiring so the fic can output the proper voltage to keep the stock ecu happy in closed loop. is that what clamping is called? when done to the o2 or maf?
at what cfm does the maf hit 5 volts? is it even possible with the t14?
as for open loop.... im sure its the same for all 1zfe's? when does it switch over from closed? i know wot is open...
Old 01-20-2011, 02:05 PM   #4
For the 02 Sensors:
Sensor 1: 0 to 7.999V
Sensor 2: 0 to 1.275V
The MAF sensor normal operating voltage range is 0.4V to 2.2V (below 0.2 and above 4.9 will trigger a DTC).
The three conditions that I know of that cause open loop are coolant temp below 75C, WOT, and O2 Sensor below a certain temp (I don't remember what temp off the top of my head).
I have done some experimentation with forcing open loop, but have yet to find a method that doesn't eventually set a DTC. Fooling the coolant temp input seemed like it was going to work, but keeping it in that state for more than 900 seconds (15 minutes) of driving causes an "Insufficient Coolant Temperature for Closed Loop Fuel Control" to be logged.
Old 01-20-2011, 03:55 PM   #5
Focus_Sh1ft
Directly from the electrical master....
Yeps.
The way I see it is you're going to get a CEL no matter what you do when attempting to force open loop. Why not just unplug the AFR sensor and take complete control?
I think the only method that hasn't been thoroughly tested in forcing open loop was by decreasing the amperage that reaches the O2 heater. I remember I was reading it supposedly won't throw a code if it's above .8A, and usually it operates at a higher amperage during closed loop. However it's likely it would throw a code anyway if it didn't heat up within an certain amount of time.
Toyota =/= Subaru in the slightest when it comes to aftermarket ECU tuning lol.
Old 01-20-2011, 04:43 PM   #6
Scubaru Steve
Awesome!
i dont mean keeping it in open loop. as for not being able to heat up the o2 sensor that will give it a shorter life span and probably throw a code.
on page 18 of the instructions its saying "fixed" mode the fic outputs a square wave that alternates between the bank high and low voltage.
maybe ill just do the open loop for now then mess with closed.
anyone know where closed ends and open starts?
also... anyone have problems with bov's? i know it runs rich for a split second, but does the ecu try to solve that?
Old 02-20-2011, 12:03 PM   #7
Scubaru Steve
Awesome!
alright, so im sure this is more difficult with an automatic. but does anyone know where closed loop ends and open loop takes over? i also think that if i take a small amount of voltage away from the 02 sensor during boost in closed loop i may be able to get low 13's out of it, (at least away from the 14-15) if there are any fic gurus please feel free to chime in.
Old 02-20-2011, 11:40 PM   #8
Just so everyone is on the same page, the Echo ECU and Yaris ECU are COMPLETELY different in their logic. The Yaris is more hard core.
You could try clamping the intake air temp sensor at -40°. I don't know if it'll force closed loop but you should be able to switch it on the fly without setting a code as the ECU would simply thing the air suddenly got really cold.
Have you had a look on the Scion forums yet? They might be able to shed more light on open/closed loop as they're more closely related.
Old 02-21-2011, 01:58 PM   #9
Focus_Sh1ft
I don't know how they differ in operation, but open/closed loop should still behave the same way.
You definitely have the right idea by subtracting voltage from the O2 to change the desired AFR in closed loop.
Old 02-21-2011, 06:49 PM   #10
Scubaru Steve
Awesome!
well i went out there to tune it today, just got back, i added as much as 3.1% more fuel at 6000rpm, it sits nice at 11.1 afr. i have it set to pull 3* timing.
this turbo auto is so awesome, brake stand make the rear of the car sit 2 inches lower and then the brakes can hold 5psi off the line..
Not sure where closed loop ends so i'm using 3800 rpm to introduce fuel. no bogging issues.
im impressed with this little car!
Old 02-22-2011, 10:08 AM   #11
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Just be careful when below 3800rpm. Partial throttle can still make boom.
Old 02-22-2011, 12:57 PM   #12
Scubaru Steve
Awesome!
i know that, its an auto so if you want any power out of it, the car downshifts and all goes well.
today i'm doing some data logging and going to see how much voltage i need to take away from the 02 voltage. im going to make it tickle 13-14 afr rather then the 14-15 i see. it will make fuel mileage worse but will keep everything cooler and hopefully last longer. you can only adjust at certain voltage/rpm, so this may take a while to figure out, ill probably have to adjust everwhere but idle and under 3800rpm, unless i can find out where open loop starts and i can fine tune.
not sure what psia you guys are running but im only hitting 18.
18-14.7 = 3.3psi , it is showing 5 psi gauge pressure.
i think i may try a good manual boost controler to up it to 20 psia 7psi at my altitude.
what you guys think?
Old 02-22-2011, 02:02 PM   #13
Focus_Sh1ft
In my opinion, there's no benefit to be had by having a 13-14 AFR out of boost. I'm constantly running 15-15.5 out of boost, sometimes even slightly leaner, and haven't had any issues.
A boost controller would be a good idea as well. However, if you're not hitting max boost then it's likely you have a boost leak somewhere. I currently have the same problem. A boost controller would be a good idea, but if you're getting manual make sure you get the ball and spring type.
Old 02-22-2011, 02:23 PM   #14
Scubaru Steve
Awesome!
there is no boost leak, waste gate is set to 5psi, i'm running 5psi.
the only difference is that 5psi here at 3800ft is only 3.3psi at sea level.
as for adjusting the afr's, i hit 5psi at 2500rpm in closed loop. you cannot change only for boost, only voltage at rpm. so that is the only way to change the afr's.
Old 02-22-2011, 02:27 PM   #15
Right. Yet. You're definitely shortening the life of the motor.
If that weren't so, Toyota would run the motor at that AFR too, and so would everyone else.
Old 02-22-2011, 03:41 PM   #16
i have a couple of friends with s/c'd 2zz's, here is what was said via msn...
adam barber says:
do you know how evil and pmag tuned w/ piggyback?
is it all open loop?
i seem to recall evil had some kind of trick to fool the maf or ecu or something...
drunkennewfiemidget says:
Yea..
The ECU goes into open loop when you go WOT.
So he has the TPS signal run into a relay.
And then the emanage outputs a faked TPS signal.
When it detects boost, the relay fires (digital output), switching the tps signal from the actual tps to the faked tps value from the emanage.
Putting the car into open loop.
The other option is to tap into narrowband and fake the o2 reading to have the factory ecu richen the mixture.
Old 02-22-2011, 03:55 PM   #17
Scubaru Steve
Awesome!
the tps sounds like it works.
i found a function in the fic to switch the o2 map to be switchable with boost pressure. now just need to test drive to see how well it works!
it worked sitting in the parking lot, i was able to drop it down to 12.2 at idle.
so it is tunable, now just trial and error to see how well it works.
Old 02-22-2011, 04:33 PM   #18
Aem fic 1.5ty Forced Induction Forum 17 08-16-2015 07:22 PM
aem fic $280 1.5ty Items for Sale by private party 1 10-22-2010 11:06 AM
Aem fic 1.5ty Items for Sale by private party 24 10-05-2010 03:59 PM
