#19 |
It depends on there position in the switch connector. There should be four wires entering the green connector.
#20 |
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
I'll have to take it apart tomorrow and see. I only found three wires.
#21 |
To explain this a bit better, here is a top and bottom view of an open switch with the connector plugged in:
#22 |
Okay,.. so there are four wires going into the switch. But I only found two coming out of the harness + the ground wire. The other one must be hidden inside the harness or be merged with the red/yellow wire coming out. As I put it back together already, I'm too lazy to take it apart to check, unless it really becomes necessary. It's so hot outside...
http://i.imgur.com/MmYoWzs.jpg http://i.imgur.com/AmcxmpE.jpg The good news is that the fog lights are working, and the switch is working. The bad news is that, at least as far as I can tell in super bright sunlight, the switch illumination is still on with the ignition off. I guess I can snip the "third" red wire, i.e. the one next to the grounding wire, to resolve this issue? I don't really need switch illumination or dash light; when it's dark I can tell by looking where I'm supposed to be looking while driving, to tell if they're on. |
#23 | |
The reason the light is still on is that the lighting and switching circuits are bridged. In order to separate them, you have to split all four wires apart.
#24 |
Snipped wire, and nothing exploded. Now everything works perfect.
Thanks ctscott!! |
| DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 10:42 AM |
| replacement fog light switch? | yrsdrgn | Cosmetic Modifications (Exterior/Interior) | 4 | 07-17-2007 04:11 PM |
| Bulb Size For After Market Fog Light Kit | razzorjet2 | DIY / Maintenance / Service | 1 | 04-10-2007 02:15 PM |
| Reverse light vs Rear Fog light | cooldavidko | General Yaris / Vitz Discussion | 3 | 01-03-2007 03:09 AM |
| question on Fog light | clfile | Cosmetic Modifications (Exterior/Interior) | 6 | 11-09-2006 07:11 PM |
