Old 07-22-2013, 07:54 AM   #1333
Viperoni
Drives: 2005 Toyota Echo
Looking forward to the results :)
2006 Saturn Ion Redline
Old 07-22-2013, 10:17 AM   #1334
kou
Drives: 08 lb
This one looks a little like your design.
Old 07-22-2013, 10:30 AM   #1335
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Hey, what do you know. Someone did that design. Guess the old saying is true that there's nothing new under the sun. What car did that come off of?
Old 07-22-2013, 10:49 AM   #1336
kou
Drives: 08 lb
That manifold is off a toyota 4e-fe engine
Old 07-22-2013, 10:54 AM   #1337
tooter
play every day
tooter's Avatar
Makes sense that it would be Toyota as it's similar to the Corolla manifold. Even the mandrel bent tubing looks familiar.
Just did a search on WIKI. That manifold design was on the last 4E FE 1.5 engine which was discontinued in 1997. In 1998 the Corolla 1ZZ FE 1.8 engine carried over the similar design.
Old 07-25-2013, 07:54 PM   #1338
tooter
play every day
tooter's Avatar
The tooter et just grew some new antennae...
So now it's off to the welder!
Old 07-26-2013, 07:24 AM   #1339
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Huzzah!
Old 07-26-2013, 03:07 PM   #1340
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Awesome! alien like...
JustDidIt is offline   Reply With Quote
Old 07-29-2013, 10:21 AM   #1341
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
Is it done yet?
Old 07-29-2013, 04:56 PM   #1342
tooter
play every day
tooter's Avatar
It's at the welder today.
When that's done
it's ready to run.
Before dropping it off, I finished porting all of the runners and bead blasted the insides as it's the last time I'll be open to do anything to it.
For comparison, this is before porting...
I should have the tooter et up and running on the car by Friday.
Old 07-29-2013, 08:32 PM   #1343
tooter
play every day
tooter's Avatar
Came up with another idea...
TOOTER II.VII
It's for a Toyota Tacoma 2.7 4 cylinder... a 2 inch thick intake manifold spacer that makes the runners 12% longer to lower the torque curve. The prototype should be done and ready for testing in a week. I'll drive it around to let the ECU learn the new operating parameters...
...and then it's off to Harry's Dyno Shop for a few runs.
Old 07-30-2013, 05:37 PM   #1344
JustDidIt
JustDidIt's Avatar
TOOTER II.VII
Awesome!!
Old 08-01-2013, 10:49 AM   #1345
Flipper_1938
Is it done yet?
Old 08-01-2013, 11:30 AM   #1346
tooter
play every day
tooter's Avatar
The welder might be done with it as soon as today...
I'm not even going to clean it up, it goes right on the car to find out if it will actually work.
edit: Just called the welder and it'll be done this afternoon!
(yipee )
Old 08-01-2013, 03:16 PM   #1347
Flipper_1938
Old 08-01-2013, 06:01 PM   #1348
tooter
play every day
tooter's Avatar
Hey Flip...
Just picked it up!
My wife is using the car today so I can't put it on yet. But tomorrow morning it'll be on the engine and I'll be driving it.
Greg
Old 08-01-2013, 07:20 PM   #1349
tooter
play every day
tooter's Avatar
Since I had the time, all of the welds got a quick bead blast to normalize the surface...
Old 08-01-2013, 08:07 PM   #1350
JustDidIt
JustDidIt's Avatar
That looks awesome!! I need to make a trip up to LA and come check the work out in person....
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
