#1369 |
No updates yet I guess...
#1370 |
play every day
Sorry, Blue.
I've been distracted with developing another tooter product... ![]() ![]() And just got the prototype running on my truck today... ![]() ![]() It made the intake runners 12% longer and really lowered the torque curve. I can slip the clutch in first gear with no gas pedal and the truck doesn't stall out even down to just 400rpm. The Yaris is running great... ...and It'll be on the dyno soon after we drive it a while to make sure everything gets settled in. Last edited by tooter; 08-14-2013 at 11:16 AM. |
#1371 |
play every day
I cut about half of the bend off of the slilcone coupling to straighten the intake because the air filter didn't need that much bend. So it's all ready to run...
![]() Just called Harry... ...dyno test is on for Saturday.
#1372 |
#1373 |
play every day
...and the Tacoma hits the dyno next week if I can find the free time.
I already did the baseline dyno, so the next one will be with the tooter II.VII.
#1374 |
Sweet!
#1375 |
play every day
On the dyno, the tooter et didn't perform any better than the regular tooter, but it didn't perform any worse either. With 111hp and 105tq the graphs are basically the same. So for all my tinkering around, I didn't actually change anything!
#1376 |
![]() Drives: 2012 Yaris SE 5-speed Join Date: Mar 2012
thanks for the data...
Tooter, please remind us. How do your fully modded figures compare with "bone stock"?
Thanks, Doug |
#1377 |
2ZR swap. DO IT! Ask how!
While it's disappointing to see that there isn't an appreciable improvement, it's certainly unique. Have you considered changing the runner length on a "standard" tooter for comparison?
#1378 | |
play every day
The results. Stock: 91hp 91tq Tooter: 111hp 105tq So with: Intake Throttle body Intake manifold Header Axle back exhaust I have 22% more horsepower, and 15% more torque with the stock ECU, no tuning, and regular 87 octane pump gas. Latest gasoline fillup today: 39.4 mpg. Total cost: $1,350 |
#1379 |
play every day
I'd also add that none of these modifications has altered the basic reliability economy or longevity of the engine. My wife's car is still just a regular daily driver that always needs to be in service.
Now it's just way more fun to drive...
#1380 |
Impressive results!
Tooter,
I would estimate you have optimized the volumetric efficiency of this particular air pump. A gain of 20 hp at the wheels is awesome. Without changes to cam timing, fuel map, and injectors (meaning access to the ECU), I cannot imagine there is anything left in a naturally aspirated Yaris. Think about it...your at the crank hp is pushing 125+. |
#1381 |
That bone stock dyno chart is not your car, correct? There will be natural variation in that number (note the 93 degree temps for example, warm day!) You've been a big proponent of posting charts for the same car, under the same conditions, on the same dyno, which are awesome when someone bothers to do it, as you have.
The before and after tooter dynos were especially helpful. ![]() Tooter, how did you get the car to rev to 6500? I thought stock rev limit (as shown on the stock dyno) was 6250. I'm also not sure the difference between SAE and STD smoothing -- anyone know?
#1382 | |
![]() ![]() ![]() ![]() ![]() Drives: Toyota Yaris Sedan 09 STD Join Date: May 2009
#1383 | |
play every day
And the dyno runs tell only part of the story. In normal daily operation nothing was conceded to drivability or to getting excellent gas mileage. I believe this is because I didn't alter the factory electronic engine management and instead turned my attention to the issue of flow.
#1384 | ||
play every day
#1385 | |
![]() ![]() ![]() Drives: '08G2T Prius Join Date: Oct 2012
Tooter, I really plan on coming up in the next 2 wks or so. I'd like to meet up and talk with you about my ideas for my 1NZ-FXE. It includes a few items like the ones below... ![]() Last edited by JustDidIt; 08-19-2013 at 02:29 AM. |
#1386 | |
play every day
![]() PM me in advance before you come so that I can set some time aside from work, and we can explore the possibilities. Oh oh, stainless. That's a lot harder to work with than aluminum. But it's still buildable material. ![]() Greg |
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
