Old 08-22-2013, 03:48 PM   #37
I've copied it over to the Echo product page, it has a slightly different part number than the Yaris one. You should find it there now. I have two in stock.
Old 08-23-2013, 01:12 PM   #38
echoeguy
Drives: echo
Thanks again Cali.
I watched your install video. So you figure if you didnt raise the axle beam the bracket would have fit without grinding it down?
echoeguy is offline   Reply With Quote
Old 08-23-2013, 01:54 PM   #39
^ That was on the Yaris, and yes, probably because I'm using the alternate set of holes.
Did not see this problem at all on our Prius C install, and you probably won't on your Echo. But do take a look when you do your install.
xA or xD front sway bar fit in to 07 Yaris yariseggvvti Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 10-29-2012 09:47 PM
WTB: Rear sway bar weedtank Willing to Buy by private party 4 02-08-2012 01:50 AM
Rear sway bar snow clearance? CrankyOldMan Performance Modifications 19 09-15-2011 01:40 AM
FS: TRD rear sway bar 19mm brand new in box hksir Items for Sale by private party 7 02-12-2011 08:07 PM
Is the TRD rear sway bar a worthwhile upgrade? YellowJolt Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 07-15-2009 08:07 AM
