![]() ![]() Drives: 2012 Yaris LE Join Date: Oct 2012
Cruise Control kicking itself out
I was on the highway today doing 110km/hr with CC set. CC all of a sudden kicked out. Thought I hit the stalk with my knee so I quickly flipped the stalk up to re-engage the speed I locked it into. Nothing. Turned off/on CC and set again for 110. A little while later it kicked itself out again and again flipping the stalk upwards it did not want to re-engage.
Has anyone else ever have this happen to them? |
Do you have an AT or an MT? It could be either the brake switch or clutch switch (if it is an MT) triggering too easily.
It's a MT. Could be but why would it wipe out the memory of the last cruise speed?
Newbie DIYer
Drives: 2010 Yaris LB MT Join Date: Dec 2010
I had the same problem with a 2010. There was a loose connection in the (aftermarked but dealer purchased) stalk. Manufacturer defect. It was before I started doing my own work and I made the dealer fix it.
#5 | |
Do both the CC and SET lights stay on on the cluster when it is in that state?
The CC light stays on but I cant re-engage it.
Is there a point when a CC will disengage itself? |
The only thing that can cause that is if the vehicle speed drops below the set point by more than 10 MPH. In that case it will disengage and you have to set the speed again.
Ahhhh...that's it then. It was climbing a hill. I guess it went too slow. But strangely this hasn't happened before.
Awesome!
Drives: 12 Yaris/07 yaris Join Date: Dec 2010
mine does that climbing a long hill, the engine is to loaded up and can not keep up. loose 15 kph and cuts out. its normal
its your cars way of telling you to downshift. |
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
Maybe CTScott can build a circuit to give the audible command:
"please downshift now" kinda like when a GPS tells you to turn here.
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| Rostra 250-1731 cruise control kit for Yaris | PeetYaris | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 06-26-2011 06:48 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
