Old 09-25-2013, 04:11 AM   #1
xsqr
Drives: Toyota Yaris III 1.33
Idle rotates failure?!
Hi
I'm writing on this forum from Poland because on our forums I can't find any reasonable responses.
Two months ago I bought brand new Toyota Yaris third generation with 1.33 engine and 6 speed manaul gearbox.
First month of car usage was deprived out of any worries but a few days ago i observed that engine rpms when car stops on traffic lights or in garage are randomly stayed - usually between 800 and 1000 rpm (on warm/hot engine)
Sometimes just after stop rpms a re stopped @ 980, then goes down to 900 and goes back to 900rpm.
Is it proper ? Tomorow I will goe to my dealer to diagnose that issue.
xsqr is offline   Reply With Quote
Old 10-18-2013, 02:46 PM   #2
cosmin1984
Drives: Toyota Yaris 1.33 DUAL VVT-I 2
Hi,
Did you get any answer from your dealer ...... I have the problem present in my post ...... Toyota Dealer checked and diagnose was very good but the idle is not smooth and the car has a little vibration at idle. I guess we have consider this as normal::(( 1.33 VVT-I/2012 owner.
cosmin1984 is offline   Reply With Quote
Old 10-19-2013, 01:28 PM   #3
Geoff Peace
Drives: Yaris 1.33 litre 2011
Originally Posted by xsqr View Post
Hi
This is not normal. My wife has owned a Mk3 Yaris, 1.33 petrol engine 6 gears for over two years now and has never experienced this fault. I would go to the dealer for it to be corrected.
Regards Geoff Peace.
Geoff Peace is offline   Reply With Quote
Old 12-10-2013, 01:00 PM   #4
cosmin1984
Hi,
Did you get any statement from the dealer related on your issue ?
Old 12-10-2013, 01:47 PM   #5
IllusionX
Drives: 07 Yaris Sedan Aero
The IDLE does fluctuate when AC is on though.
It also fluctuates when the radiator fan turns on and off.
Old 12-10-2013, 03:42 PM   #6
esse10
Drives: 2009 yaris 2 door
Idle
Hey you are doing good if yours is Idling at 800+ rpm. Mine go's down to 500-400 sometimes but it always fluctuates with A/C on or off .To answer your question, yes it's normal to fluctuate.
esse10 is offline   Reply With Quote
Old 12-10-2013, 04:15 PM   #7
IllusionX
it really depends on the engine's temperature.
mine does around 800 when AC on, and i'm around 650rpm when engine is fully warmed AC off.
I'm often around 900 when the COOL light just turned off, but in reality, engine is not fully hot.
Old 12-11-2013, 11:17 AM   #8
cosmin1984
My engine 1nr fe 1.33 VVTI Yaris 2012 has a vibration at idle.... please check my post ..... Dealer checked engine with OBD but no errors in history car..... anyone experienced this before?
DIY - 1.8L 1ZZ-FE TB Connector Chip Swap Yaris T-Sport DIY / Maintenance / Service 332 04-03-2022 01:39 AM
1.33 DUAL VVT-I 2012 Toyota Yaris Vibrating at idle cosmin1984 DIY / Maintenance / Service 16 02-10-2014 12:37 PM
rough idle.... dindy Third Gen Yaris General Discussion 5 06-12-2013 12:48 PM
3rd gen 1zz tb swap mr_miles DIY / Maintenance / Service 26 05-01-2013 08:20 AM
Help with low idle from Venezuela Yarisvene DIY / Maintenance / Service 5 06-23-2007 08:23 AM
