Old 01-22-2014, 06:27 PM   #1
soldout
soldout's Avatar
Drives: 2010 Blazing Blue 3 Door LB
Replace cargo light?
Does the light cover pop off or do you have to remove the entire panel? Thanks.
15' - Crosstrek Hybrid ~ Plasma
10' - Yaris 3 Dr LB ~ The Boom Box
06' - RSX Type S ~ H.S. Dream Car
95' - Delsol VTEC ~ The Racecar
12' - Burgman 400 ~ Garage Queen
09' - Agility 125 ~ 80mpg Daily Rider
09' - Metropolitan ~ Weee
14' - Ecosmart Metro ~ Razor
soldout is offline   Reply With Quote
Old 01-22-2014, 06:45 PM   #2
The light assembly pops out.
Old 01-23-2014, 12:15 AM   #3
soldout
soldout's Avatar
Im having a hellofa time getting it to pop off. Any particular spot I should try to pry at?
Old 01-23-2014, 07:56 AM   #4
It comes out relatively easily. One side is a squeeze tab and the other is a tab that slips behind, so you have to make sure you are on the squeeze tab side. If memory serves me right, it is the side closer to the hatch that you want to pop it on, but I will check on one of mine for sure and let you know.
Old 01-23-2014, 08:32 AM   #5
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
IIRC, the point to pry has a small groove on it
dj92 is offline   Reply With Quote
Old 01-23-2014, 11:51 AM   #6
That's correct - There is a groove and it is towards the back of the seats (as opposed to towards the hatch). The plastic lens is crazy brittle, so don't try it if it is really cold.
To remove it you slip a very thin screwdriver or plastic blade between the lens and the black plastic and push towards the hatch to release the clip, while lifting outward.
Old 01-25-2014, 02:42 PM   #7
soldout
soldout's Avatar
I was able to change the bulb.
Old 08-01-2015, 04:59 PM   #8
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
weird, mine has the squeeze tab facing back. i was prying the wrong side and almost broke the thing. then when i removed it, i realized i had a wrong bulb. it's much bigger compared to the dome light bulb. all the other toyota cars i have have the same dome and trunk bulb.
jack black is offline   Reply With Quote
2012 Yaris LE Check Engine Light On/Eco Light Off 2012YarisLE DIY / Maintenance / Service 1 01-22-2014 12:29 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 02:50 AM
cargo area light question why? DIY / Maintenance / Service 4 10-07-2010 07:41 PM
My Yaris Fog Light ezlove0710 DIY / Maintenance / Service 7 08-07-2009 07:15 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 11:42 AM
