Old 02-03-2014, 06:03 PM   #55
Got a selling price set yet? I couldn't spot mention of $$s in this thread.
Old 02-03-2014, 06:40 PM   #56
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
nice .65HP and 3.2lbft torque. now if you can get the production price and kits together.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood
Old 02-03-2014, 06:54 PM   #57
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Not yet... I just ordered a dozen blocks for the first production run and the shop hasn't gotten back to me yet on the material cost.
From the original concept on November 29th to a dyno tested prototype took only a little over 3 months and that was with the holidays. So if all goes well, I should have finished products ready to ship in another month for a total elapsed time of 4 months from virtual concept to the reality of a finished product ready to sell.
This is the advantage of a microbusiness where just one person calls all the shots.
Greg
Old 02-03-2014, 07:19 PM   #58
tooter
play every day
tooter's Avatar
I'm working on it right now...
The negligible horsepower increase is only incidental as this was not designed to be a top end high performance accessory. The purpose of this spacer is to make regular daily driving easier because the engine doesn't have to work as hard at low rpms.
And the increased torque peak really isn't all that much either. Most all of the advantage comes from shifting the whole torque curve down lower in the rpm range. So as the two torque curves are climbing, the spacer curve remains above of the baseline curve. This spreads the torque increase over a larger rpm operating range.
This mod is for just regular low rpm daily driving.
Greg
Old 02-03-2014, 10:29 PM   #59
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Anyway to overlay this with a tooter dyno as well?
Btw madness on the midrange gains!
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 02-04-2014, 12:45 AM   #60
tooter
play every day
tooter's Avatar
That's a great idea. I'll see if Harry can do it. I need to talk to him about the chart anyways as the peak numbers don't match up with the line on the chart, so one or the other isn't right.
The tooter manifold with the larger throttle body makes 111 horsepower, so it's graph will be a lot stronger at the top.
It would be run 16 with the plain tooter intake manifold and the 1ZZ throttle body...
...and run 23 with the stock manifold and the tooter I.V spacer.
Longer intake runners making more torque is a sound mechanical principle that worked out really well on my Tacoma, so I figured, heck, why not for the Yaris too?
Greg
Old 02-04-2014, 03:20 AM   #61
7:34pm
Drives: 07 Yaris
If you have the resources, you should experiment with different spacer sizes to find the optimum length. I'd be curious to see the different outcomes.
And then run them all on the dyno, on the same day so there is no discrepancy between the variables.
7:34pm is offline   Reply With Quote
Old 02-04-2014, 04:12 AM   #62
I like the bump in torque and where the bumps are in the band.
Old 02-04-2014, 08:49 AM   #63
Silver Streak
Silver Streak's Avatar
Drives: 2010 Yaris sedan silver
I'm very excited about this spacer. Most of my driving is done in this rpm range, and will make the 1.5's acceptable torque even better.
k&N Pannel air filter
Trd Exhaust
Trd Rear Sway Bar
Silver Streak is offline   Reply With Quote
Old 02-04-2014, 12:41 PM   #64
tooter
play every day
tooter's Avatar
There's something that doesn't show up in the dyno runs, and that's partial throttle performance at extremely low rpms right down to idle and even below. This is because the dyno runs done by mashing the gas pedal to the floor at 1,300 rpm in third gear. This is an extreme condition that is not encountered in normal driving. Very low off idle torque is exceptionally good especially when taking off from a stop with a manual transmission. On level ground even if you let out the clutch and forget to use the throttle, the engine doesn't die. Instead the car slowly moves forward without any bucking.
Greg
Old 02-04-2014, 12:44 PM   #65
In the meantime, can you source a shipping quote to L0P 1K0 Ontario, Canada? Preferably USPS.
Old 02-04-2014, 12:54 PM   #66
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
sweeet!
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!!
"Horsepower is how fast you hit the object. Torque is how far you move that object.."
Old 02-04-2014, 01:02 PM   #67
tooter
play every day
tooter's Avatar
Sorry, I don't have the time or the resources.
This is just a hobby I do on the side in my free time off of work. Dyno time gets really expensive when your car is on the machine and you're trying to swap out parts. Adding the cost for new CNC programming would make it unpractical to make a bunch of different sizes. Anyways you can simply extrapolate the difference as a one inch spacer would make half the torque as a two inch.
I picked 2 inches because that is the thickest spacer which will work without interfering with the engine peripherals like the oil dipstick tube. The two inch simply drops into place like it belongs there.
Other intake manifold spacers sold like this one for a Toyota Tacoma V6 are usually only a half inch thick...
...while the tooter I.V is like stacking up FOUR of them.
Greg
Old 02-04-2014, 05:42 PM   #68
07stlYaris
If Its Not Blown It Sucks
07stlYaris's Avatar
Drives: 07 Yaris LB Meteorite
How about a 1/2" spacer for between the Blitz and the head? I haven't had a heat soak situation yet but this might be a pre-emptive strike. If possible, how much and how soon?
07stlYaris is offline   Reply With Quote
Old 02-04-2014, 06:09 PM   #69
Old 02-04-2014, 06:23 PM   #70
tooter
play every day
tooter's Avatar
They're already available. You can get them from Garm at MicroImage.com. Two of them make about a half inch.
Old 02-04-2014, 06:39 PM   #71
tooter
play every day
tooter's Avatar
When they're available they'll be offered for sale at $265 including shipping. The shop still has tooter II.VII Tacoma spacers in the works so the I.V's will be machined once they're completed.
Greg
Old 02-04-2014, 11:10 PM   #72
Silver Streak
Bummer great mod, but out of my price range right now. I'm curious Tooter, what do you think the spacer would yield on a bone stock Yaris?
Trd Exhaust
Trd Rear Sway Bar
tooter's manifold adventure... tooter Performance Modifications 1465 07-31-2014 09:11 PM
FS : GT2560R Turbo + Manifold Parmas Items for Sale by private party 0 08-24-2012 09:35 AM
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 02:09 AM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 07:52 AM
