play every day
FS: tooter I.V 2 inch thick intake manifold spacer
This is a list where you can add your name if you're interested. It's not a commitment to buy, so you're free to change your mind. But you'll have a first chance at one in the order of the names. The spacer is $265 including shipping, and comes complete with mounting hardware and stock O ring gasket.
Production Estimation List 1. BEEF 2. Fredovvti
![]() Drives: ph2 yaris ts Join Date: Feb 2014
Whats it do??
play every day
Hi Tooter. My suggestion is that you explain in detail what this spacer does, but in layman's terms. I understand you have another thread on the production, but I'm pretty sure 85% of this community doesn't even understand why the torque and hp cross paths at 5252 on that chart let alone how this would or would not benefit them. There is a lot of information on that chart and to the person who doesn't get it just won't get it and pass it by without a second glance. Just a suggestion and good luck with the sales.
![]() ![]() ![]() Drives: 09 Meteoric Metallic 3 door HB Join Date: Jul 2010
I have another question actually...do you think this will have any benefit with boosted projects?
I'm interested, but I might go boosted eventually. |
I thought boost likedshorter runners (less area to pressurize) there again, what do I know.
#7 | |
play every day
Horsepower: How fast you hit a wall. Torque: How far you push the wall after you hit it. Horsepower is like a sprinter, while torque is like a cross country hiker. The sprinter is faster, but when you put a 70 pound pack on his back, he slows down. The cross country hiker is slower, but when you put a 70 pound pack on his back, he still moves at the same speed. Then the intake valves on your engine open and close. They are abruptly starting and stopping the incoming air. Now the incoming air has inertia so starting and stopping creates pulses, or pressure waves that travel back and forth inside of the intake manifold runners. If the runners are made longer the pulses will resonate harmoniously at a lower frequency because they have a longer distance to travel to get to the other end. A lower harmonious frequency means reaching peak torque at a lower rpm. More torque at lower rpm means the engine pulls stronger without needing to rev higher. Hope that helps... Greg |
#8 | |
play every day
The tooter intake manifold would work best for boosted applications... ![]() ![]() ...because the runners are larger in diameter, it will flow more air, it will accept a larger 55mm 1ZZ throttle body, and the strong aluminum can handle any boost pressure. Greg |
Well my current mods are a Weapon R intake, 1zz TB, DC header, and a mandrel bent cat back exhaust.
I've been debating on weather to go boost or stay NA. |
#10 | |
play every day
Greg |
![]() ![]() Drives: 07 hatchback Join Date: May 2012
Put me down for one
![]() Drives: 2007 yaris 3 door AT Join Date: Jul 2007
Put my name on the list
I'd like one. I'm automatic and I think this coupled with my Blitz throttle controller would be a perfect match for that "get away quick at the stop light." Thank you.
PS: Will this come with all the hardware for installation? If not will instructions be provided that include the specific hardware nomenclature required along with gaskets etc. Thank you again. PS2: Disregard previous, re-read thread. My dumb-a**. |
play every day
1. BEEF 2. Fredovvti 3. dragoonmc 4. jjwitter 5. Klink10 |
Form>Function
How does this work with the MI manifold. Any dynos combined with one to see how that changes things?
#16 | |
play every day
![]() I'd love to combine it with my tooter intake manifold, but there isn't enough space in front of the engine to do it. Greg |
Form>Function
Yea I was going to say, the MI manifold sits wayyyy close to the hood latch so idk if the spacer would push it too far, if anyone around you cares to test fit id be interested
are you planning on making any TB spacers? |
#CarFiend-HANZO188
Drives: 2011 Toyota Vios Join Date: Oct 2012
I'll consider this, out my name in buddy!
I N S T A G R A M- @Hanzo_Stmpng_Grnds x-Check out my build thread-x HANZO's Build Thread |
| tooter's manifold adventure... | tooter | Performance Modifications | 1465 | 07-31-2014 08:11 PM |
| stock scion xa exhaust and intake manifold and others | taman86 | Items for Sale by private party | 0 | 09-27-2012 02:39 PM |
| Intake Manifold Gasket? | Nexus1155 | DIY / Maintenance / Service | 6 | 11-18-2008 08:03 PM |
