Old 02-14-2014, 09:37 PM   #19
vaironl
vaironl's Avatar
Drives: 2010 Yaris 3 door, manual tran
I don't know poop about turbos, as I'm just starting to learn about it.
But, isn't this a well documented thread? Link: http://www.yarisworld.com/forums/showthread.php?t=30813
vaironl is offline   Reply With Quote
Old 02-15-2014, 12:04 AM   #20
^ GREAT link.
Old 02-16-2014, 05:59 PM   #21
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
Thanks for the link i have added it to the information.
Old 03-03-2014, 06:35 PM   #22
Golddeenoh
Golddeenoh's Avatar
after talking to the wife and figuring up the numbers, i'm just going to keep it going and reliable and possibly sale it to go buy me a Hemi (Challenger SRT8).
Old 03-03-2014, 09:59 PM   #23
^ I knew that was coming.
Old 03-28-2014, 02:15 AM   #24
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Detonation...reduce it by using higher octane gas (premium at least)/e85...
With e85 you're talking about redoing the fuel pump to keep up with demand. IIRC you can use C16 with a stock fuel pump because of the weight (?) of the fluid versus e85*.
Garm, your former Yaris's engine was fully built wasn't it? What did you have for compression?
*=I'm not sure on the Yaris's fuel system. On my other car, that's a yes.
Being as cheap as possible usually doesn't lend itself well. If you're going to play around with this stuff, don't get yourself stuck on the side of the road, especially if the car is your DD.
― Thomas Paine
Old 03-28-2014, 06:31 AM   #25
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Originally Posted by BEEF View Post
16# on stock internals?
Yep with 290k on em
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 03-28-2014, 08:31 AM   #26
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Unless I am totally mistaken the biggest and ppossibly only issue with going with racing fuel over the VP100 level would be possible plugging of your cat would it not?
Old 03-28-2014, 10:59 AM   #27
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
Originally Posted by malibuguy View Post
Yep with 290k on em
Sir, your ballsack must be the size of texas....
I would love to see the dyno sheet of that one. I am sure I have read (a few times over) that the absolute limit was somewhere around 10# at around 200hp at the tires. Are you sure your connecting rods aren't shaped like squiggly lines by this point
Post minimum for PM? 2mtech Suggestions - Feedback - Questions 2 09-12-2011 08:05 PM
The factory radio circuit needs to be a minimum of 15A. IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 2 06-07-2011 10:41 AM
Highway minimum speed limit bentjazz Fuel Economy Forum 33 04-12-2011 05:38 PM
ACEITES Y MANTENIMIENTOS Yaris PTY-507 Central and South America 22 10-01-2007 10:57 AM
