Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
minimum Turbo'n
What are the minimum requirements to have a simple turbo set up on the Yaris?
for instance turbo exhaust manifold down pipe piping (maybe inter-cooler) bov/waste gate (7psi) boost controller boost guage oil feed to and from turbo back to engine Coolant lines to and from turbo Piggy back required at minimum(and some way to connect it) Air/Fuel Ratio gauge anti-foulers needed(depends on tune) ungraded injectors 1ZZ (depends on tune) Additional Information from one of the Yaris Turbo masters: http://www.yarisworld.com/forums/showthread.php?t=30813
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood Last edited by Golddeenoh; 02-16-2014 at 05:56 PM. |
You can't boost the car on just the stock ECU.
psi depends on the wastegate spring. You can just run the spring and not use a controller to save money. (but I don't recommend it) You left out oil and water lines.
drop the boost to about 2-3 and you can use the stock ECU... but they why have a turbo to begin with?
like Garm said Engine management is a requirement to keep your motor safe or you will be buying a new motor not too long after that turbo is put on.
#4 | |
I want to say malibuguy did this on his echo (the low boost thing)
there isn't much point to boosting unless there is at least 7 psi of boost, giver or take 1 psi, so the management is a must.
I updated the list to include the fluid line and managment what about injectors and o2 sensor anti-foulers?
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
There's only one anti-fouler, between the cats. if you are running a stock exhaust you may or may not need it.
Injectors, you have to see, as you are basically tuning the car with them. I would have 1ZZ injectors on hand to swap in. You left off an air/fuel gauge, CRITICAL so you can monitor how your motor is running.
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
i ran 3.5 on my tercel completely stock EFI. The car was awesome. After I was sure of my set up, bigger injectors went in & so did the AEM...& now i'm running 16lbs...
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
16# on stock internals?
Mr. 155 and climbing
The Zage kit isn't a complex setup. Why not one of those or use as a model? Also need conical air filter right? Also I at a loss how an IC would be optional?
Oh yeah...I never paid attention. How well does the stock exhaust piping handle 6-8psi?
You can run a low-boost turbo without an intercooler. The air gets hotter (obviously) so it doesn't make as much power.
I don't recommend it, mostly because it's not THAT much more work to run an intercooler set up -- but it CAN be done.
The point of the thread is to obtain a turbo set up for as cheaply as possible while still being able to drive the car every day. ideally a cheaper set up that can be expanded upon.
Zage is nice but if one would start with a basic set up t3/t4 turbo, then the expansion possibilities would be better once further funds became available. I am under the impression that anything above 8psi will lead to a bent connecting rod. correct? personally, I would inter-cooler, but if push comes to shove, it can be bypassed to save a few buck but lose some HP. At some point MI will finally get a mid pipe in and stock exhaust will no longer be a problem.
#14 |
I think the point of the thread is being served quite well... for once.
#15 | |
#16 |
For the most part you aren't going to start risking rods until over 10psi, but if you have a shit tune I would think it is possible to ruin a rod. Regardless of that if you run lean all the time you could damage even at 8. It also depends on how you drive it.
#17 |
![]() ![]() ![]() Drives: Scion xA Join Date: Oct 2009
Hey guys remember, boost doesn't bend rods. Power and detonation does. I built my roomies xB and with a 3.5psi wastegate spring it is making more power than the stock motor should handle because it has a t3 60 trim coupled with an efficient setup. When I had my Greddy kit I needed to run 15 psi to make the same power.
Ptuning.com |
#18 | ||
| Post minimum for PM? | 2mtech | Suggestions - Feedback - Questions | 2 | 09-12-2011 08:05 PM |
| The factory radio circuit needs to be a minimum of 15A. | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 06-07-2011 10:41 AM |
| Highway minimum speed limit | bentjazz | Fuel Economy Forum | 33 | 04-12-2011 05:38 PM |
| ACEITES Y MANTENIMIENTOS | Yaris PTY-507 | Central and South America | 22 | 10-01-2007 10:57 AM |
