Old 02-28-2014, 10:30 PM   #109
bonnorano
Drives: jdm wannabe yaris
Hello everybody i missing a dimmer switch on my indonesian/thailand yaris 2012 5doors, i want to add tachometer on my yaris. Please help me :(
bonnorano is offline   Reply With Quote
Old 02-28-2014, 10:34 PM   #110
The Asian market Yaris do not have the dimmer rheostat. You can either just use ignition switched power for the tachometer illumination wire of you can use the illumination wire on the radio.
Old 03-11-2014, 08:43 AM   #111
Mittelklasse
Problem, officer?
Mittelklasse's Avatar
Drives: '06 Yaris 5DLB 1.5
My Thailand-spec Yaris uses electronic dimmer circuit built within the instrument cluster.
You have to toggle the trip button while having your lights on to access this function.
Mittelklasse is offline   Reply With Quote
Old 06-26-2014, 04:41 AM   #112
BADIS
Drives: Toyota Yaris 2007
Hi all. I'm planning to buy and mount a tachometer and water heat gauges on my Yaris 2007 Sedan. I've seen some loose wires and harnesses near the engin. These are unplugged . My yaris is number 2. It comes without RPM and Water heat Gauges. I bought it in Sultanate of Oman. My question is: does Yaris come with ready harnesses to plug and play my gauges? Otherwise, could you please show me how to mount them? What and where are the right wires located?
Thanks in advance
BADIS is offline   Reply With Quote
Old 10-25-2014, 11:34 PM   #113
THEBRADLEY
Drives: 06 hatch
hey man i was wondering if you could tell me how to go about installing footwell led lights to be activated with a switch prefferably in the center console by the e-brake. i know you have to bypass the firewall somehow for power, but i have no idea how/where to do so. help would be greatly appreciated.
THEBRADLEY is offline   Reply With Quote
Old 11-01-2014, 12:28 AM   #114
"G"
Drives: 2007 Yaris Hatch
Where is the wire for the seat belt alarm?
"G" is offline   Reply With Quote
Old 11-01-2014, 07:52 AM   #115
The driver's side one is under the driver's seat and then it goes under the center console directly to the SRS ECU. The passenger one is under the passenger seat and it goes to the Occupant Classification ECU and then that ECU communicates with the SRS ECU to relay the info.
What exactly are you looking to do with that wire?
Old 11-01-2014, 07:54 PM   #116
wufai
Drives: Silver Yaris Sedan (4A)
So does that mean if I want to steal a yaris like they do it in the movies I need to cut the yellow, pink and black wires and tap the yellow leads against the pink and black?
wufai is offline   Reply With Quote
Old 11-18-2014, 09:10 PM   #117
gabbhie
Drives: yaris sedan
hi CTScott. where can i see the hotwire for parklights that is usually used in aftermarket alarms..when you press the lock/unlock button of alarm the parklight will blink once or twice.
gabbhie is offline   Reply With Quote
Old 11-18-2014, 09:13 PM   #118
Look at my remote start wiring guide for where you can grab the parking light feed. Just verify that the wire colors match, as the Yaris in your market may be wired a bit different.
http://www.yarisworld.com/forums/showthread.php?t=24860
Old 11-18-2014, 09:22 PM   #119
gabbhie
Drives: yaris sedan
oh i see, but i already tried that wire. its not the wire for the parklights.
i have owned my yaris since last year and until now theres no park light signal when i lock/unlock
Old 11-18-2014, 09:34 PM   #120
Post some pictures of the connector for your headlight switch.
Old 11-18-2014, 09:43 PM   #121
gabbhie
Drives: yaris sedan
ok sir i'll post pic once i got home laterTIA
Old 02-03-2015, 11:00 PM   #122
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
CTScott do you have a wiring diagram for the 3rd gen Yaris? In particular I'm interested in the body ECU and what wires go where.
Old 08-25-2015, 01:09 PM   #123
Kitt
Kitt's Avatar
Drives: Thndr cl metallic HB 3 drs '05
Send a message via MSN to Kitt
Im planning to add a gauge 2 cable for my amp on my new car from the battery, however, I'm not sure where is the right place to do so. Do I have to drill the firewall?
20 years... alive and kickin'!!
Kitt is offline   Reply With Quote
Old 08-25-2015, 07:45 PM   #124
There is no power feed inside the cabin that you can connect that large of a wire to. You can go through the large grommet that is behind the battery, rather than drilling the firewall.
Old 01-21-2016, 01:27 PM   #125
frankienap
Drives: Yaris 2008 Sedan
Desperately looking for the 12v + reverse wire on the rear tail light
Looking to add power to an aftermarket backup camera. I've searched for over 3 hours for the location of this wire. Here's a picture of the connection for the left rear light assembly on my 2008 Yaris Sedan. Anyone know which wire?
The wires going into the rear lights are: purple, green, orange, white w/a black strip and light blue.
Many many thanks!
frankienap is offline   Reply With Quote
Old 01-21-2016, 02:25 PM   #126
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
If nobody answers, you could get a test light and turn the key to accesories. With the hand brake up, you could just put it in reverse. Use a test light and back probe each wire. Record which ones have power. Then put it back into park and check again to see which one no longer has voltage. I can't look up the wire diagram right now while i am at work. CTScott would be the one to get the info to you the fastest.
-Derrick-
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 03:55 AM
New Yaris race car Jason@SportsCar Tracking, Racing, Auto-X Forum 83 11-01-2012 02:32 PM
