Old 02-07-2014, 01:16 AM   #91
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Originally Posted by malibuguy View Post
I may just have to get this...trade for my tooter? My car is DD more then race car ;)
Sure, man.
I'll swap you straight across for a spacer as long as the tooter kit is unused. I'll pay the shipping to you if you pay the shipping to me. I have a Corolla manifold sitting in my shop that I need to build, and it'll save the CNC engineer the time to make another set.
Greg
Old 03-02-2014, 05:14 PM   #92
teoek9
teoek9's Avatar
Drives: toyota yaris 08 sedan
How can I get one of those tooter adapter.
teoek9 is offline   Reply With Quote
Old 03-02-2014, 05:19 PM   #93
http://www.yarisworld.com/forums/sho...0&postcount=38
Old 03-07-2014, 06:40 PM   #94
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Originally Posted by tooter View Post
Here's the prototype on the manifold...
Greg
The tooters are done...
$265 including shipping
Greg
I'm really thinking about pulling the trigger on this and trying it on my 1NZ-FXE.. Should bolt right up.
JustDidIt is offline   Reply With Quote
Old 03-07-2014, 07:45 PM   #95
tooter
play every day
tooter's Avatar
If your intake manifold looks like this...
I have no idea as to the spacer's effect on your engine...
However, it would be an interesting experiment because you have an Atkinson cycle engine and not an Otto. You'd also need at least 3 inches of free space in front of the intake manifold for the spacer to fit. From the drastically shallow design of that manifold it looks like free space might be at a premium. But I don't know your under the hood situation. Can you post a pic of the space in front of your intake manifold? Then you can go from there. Don't get one without first finding out if it would even fit.
Greg
Old 03-07-2014, 09:25 PM   #96
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
DOOOO EEEET! Dyno runs or it didn't happen!
Old 03-08-2014, 10:52 AM   #97
tooter
play every day
tooter's Avatar
The only issue I can see is that very strange 1-2-4 (opposite of a 4-2-1 tri y exhaust manifold) intake manifold is specifically designed for an Atkinson cycle engine and is tuned for a very specific optimal rpm range. So an intake manifold spacer lengthening those extremely short intake runners is likely to push the curve outside that range. While there's a chance it might make it better, there's a greater chance of making it worse.
Greg
Old 03-08-2014, 01:01 PM   #98
jetblast
Drives: Gen 1 XB
First off, thanks to Greg and Garm for all the fun stuff for these engines. Wondering about matching a spacer up with my dated Weapon R manifold. Greg, even if Malibu Guy's Tooter is used I might be interested. I also have a spare Corolla manifold that I've been meaning to "Tooterfy" so either way.
Thanks, Ken
Why strive for a JDM BB, when you can promote the Scion badge?
jetblast is offline   Reply With Quote
Old 03-09-2014, 12:05 AM   #99
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Mine isnt used but it is...if that makes any sense
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 03-09-2014, 12:11 AM   #100
tooter
play every day
tooter's Avatar
The last tooter I sold on ebay was listed in the category of "remanufactured" because it was a combination of old and new parts that were made into different product.
Greg
Old 03-09-2014, 10:28 PM   #101
dragoonmc
Drives: 07 hatchback
If this spacer is a hit I think someone needs to make a replacement engine cover to go with it
dragoonmc is offline   Reply With Quote
Old 03-11-2014, 04:50 PM   #102
JustDidIt
JustDidIt's Avatar
Greg
My 1NZ-FXE
Old 03-11-2014, 09:16 PM   #103
tooter
play every day
tooter's Avatar
My 1NZ-FXE
Hey wait a minute... that intake doesn't look stock. Did you make a custom CAI for it?
There's an experiment you can try...
Unbolt the 5 bolts holding the intake manifold, yank all the hoses and put them out of the way, and then measure how far away from the head you can pull the manifold before anything hits the plastic reservoir of anything else in front of the engine. That will let you know whether or not a spacer will work. To me it looks tight in there, but it's hard to tell from pics. You'd know better than anyone else because you're right there.
Greg
Old 03-22-2014, 05:51 PM   #104
dumbo0
dumbo0's Avatar
Drives: Betsy - 07 Yaris HB
Any update on the mileage?
WILDY imaginative
WONDERFULLY expressive
dumbo0 is offline   Reply With Quote
Old 03-25-2014, 01:53 PM   #105
I filled up once so far after installing the Tooter spacer. You can track my mileage here:
http://www.fuelly.com/driver/07vios/yaris
So far, a slight increase in mpg. A bit too early to tell though.
Old 03-25-2014, 09:27 PM   #106
Just filled up this morning, however it's missing about 30 miles of city driving. So my last two fill up's are with the Tooter spacer.
Old 03-26-2014, 12:07 PM   #107
tooter
play every day
tooter's Avatar
Thanks, Laz, for posting your gas mileage results. They're more credible coming from you than from me.
It took a while for me to find out that the spacer allows the engine to operate just fine at lower rpms (1,000rpm to 2,000rpm) without any strain or lugging...
...even though my wife still revs it up.
Greg
Old 03-31-2014, 10:01 AM   #108
Greg
No problem. So far, three tanks with the spacer on now. Something to keep in mind is I don't know if my local Chevron has switched back to summer blend or not. But if comparing to around the same time last year, it's a 2-3 mpg increase.
3/22/13, 318.8 miles, 7.92 gallons, 40.2 mpg, $4.060
vs
3/20/14, 340.9 miles, 8.06 gallons, 42.3 mpg, $3.940
3/25/14 313.0 miles, 7.17 gallons, 43.7 mpg, $3.940
http://www.fuelly.com/driver/07vios/yaris (same link)
tooter's manifold adventure... tooter Performance Modifications 1465 07-31-2014 08:11 PM
FS : GT2560R Turbo + Manifold Parmas Items for Sale by private party 0 08-24-2012 08:35 AM
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
