Old 03-29-2014, 09:25 PM   #1
Hershey
How do these spark plugs look to you ?
Had them changed out at Toyota service center while in for suspension work . Replaced with DENSO SK16R11 plugs at $8.99 each . Car was idling rough , so had them replaced , seems no better . The tech lost one of the nuts for the engine cover and will likely have to order one at $2.35 . Here are pictures of used plugs at NGK , http://www.ngksparkplugs.com/tech_su...qs/faqread.asp . Which one looks close to these ? Don't look that healthy to us .
Old 03-29-2014, 10:27 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I needed to replace the nuts myself a few times. I just purchased them at local hardware with the correct thread and have done fine. NO worrying about ordering any. Just a thought.
Old 03-29-2014, 10:34 PM   #3
fnkngrv
fnkngrv's Avatar
Check Spark Plug Condition
Looks like you could have a mixture of a couple conditions there.
Old 03-29-2014, 10:37 PM   #4
Those plugs don't look bad for 73K miles.
Old 03-29-2014, 10:40 PM   #5
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
I like how ash fouled and worn are the same image....
Sent from my C6902 using Xparent Skyblue Tapatalk 2
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 03-29-2014, 11:31 PM   #6
Hershey
What two conditions are you referring too? Is that with the NGK pics ? I was thinking that the PCV may be not working properly. Maybe I will clean it out or get a new one. Thanks
Old 03-30-2014, 10:18 AM   #7
Hershey
Thanks , but I expect to get it back the way it went in with all the parts . It's less than $2.50 . They're going to try to locate it , if not , hopefully a new one through parts .
Old 03-30-2014, 05:38 PM   #8
esse10
Drives: 2009 yaris 2 door
seafoam
looks like a candidate for a Seafoam cleaning at the Intake manifold. Did wonders for my 200k mile new beetle.
esse10 is offline   Reply With Quote
Old 03-30-2014, 06:02 PM   #9
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Seafoam ...does really work ? I did my plugs at aground 140km and they looked clean nothing like urs ....also did u clean ur throttle body mine was dirty would stick and caused bad ideal , easy to do just make sure u have key on and someone on the throttle pedal when cleaning or ur get we'll May engine light .
Old 03-31-2014, 11:00 AM   #10
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
Little wear but lots of carbon. Any oil consumption? Is this short trip driving? If so, this car needs some hwy driving or Italian tuneup.
jack black is offline   Reply With Quote
Old 03-31-2014, 11:06 AM   #11
fnkngrv
fnkngrv's Avatar
Like Scott said with over 70k the results are not bad per se. Personally I would verify after 15-20k more miles how new ones look just for due diligence sake.
From my m-o-b-i-l-e
Old 03-31-2014, 10:45 PM   #12
Hershey
No oil consumption . Usually 50 or more miles per drive on urban roads , interstate and some city . Did use some Chevron Techron for the tank before removal of the NGK and install of the new Denso , probably around 300 miles of driving of Techron on the NGK .
Old 03-31-2014, 10:53 PM   #13
Hershey
More pics of NGK the plugs .
Old 04-01-2014, 06:10 AM   #14
bronsin
bronsin's Avatar
They are OK. Just gap them and put them back in for another 200,000k miles.
Old 04-01-2014, 11:33 AM   #15
jack black
jack black's Avatar
Are these the same plugs as the OP? They look much better in this picture indeed.
Old 04-01-2014, 12:31 PM   #16
Hershey
Yes , these are the NGK IFR5A11 installed at the factory .
Old 04-05-2014, 10:28 PM   #17
Hershey
Got the nut in the mail and put it on . The car is still idling a bit rough . Oh well .
Old 04-05-2014, 11:05 PM   #18
jack black
jack black's Avatar
Have you cleaned the TB and checked the engine mounts?
Location of Spark Plugs KEVBD DIY / Maintenance / Service 7 02-03-2012 11:05 AM
Laser plugs? - Awesome Altitude Off-topic / Other Cars / Everything else Discussions 1 04-24-2011 08:02 PM
article on spark plugs and the fit kngrsll Performance Modifications 4 08-01-2009 11:50 PM
did autolite spark plugs screw up coil or coils ?? la_scanner DIY / Maintenance / Service 20 04-09-2009 02:07 PM
Upgraded Spark Plugs For Boost whooppee777 Forced Induction Forum 9 02-14-2009 01:53 PM
