Old 04-01-2014, 08:30 PM   #19
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Does it fit without those big washers?
Sent from my iPod Touch
Old 04-01-2014, 08:40 PM   #20
KTS
KTS's Avatar
Drives: Vitz RS
Yea it would I guess. But it needs the washers as gas as I know.
Klick
KTS is offline   Reply With Quote
Old 04-01-2014, 08:43 PM   #21
Bluevitz-rs
Does the offset bushing fit in opening tight or loose without the washers?
Old 04-01-2014, 08:51 PM   #22
KTS
KTS's Avatar
Drives: Vitz RS
Loose very loose. The Whiteline bushing with the washers are the same size as oem 62mm. I measured it before removing d OEM bushings.
Klick
Old 04-01-2014, 08:52 PM   #23
KTS
KTS's Avatar
Drives: Vitz RS
Btw thanks for assisting.
Klick
Old 04-01-2014, 08:54 PM   #24
Bluevitz-rs
I guess if it doesn't fit without modifying the car to fit it can't be the right kit.
But it looks like the smaller round part of the washers should fit inside the space
Old 04-01-2014, 08:56 PM   #25
Bluevitz-rs
Whiteline Bushing Install Questions
Remember it should be a very tight fit. So if it doesn't slide in you might just need to give it a little motivation.
Old 04-01-2014, 08:57 PM   #26
KTS
KTS's Avatar
Drives: Vitz RS
Yea the smaller round part fits inside the spaces but then they are not in a line thus the bolt doesn't fit thru them. Also the hole for the top washer doesn't line up with the top bolt hole too.
Klick
Old 04-01-2014, 08:58 PM   #27
Bluevitz-rs
So if you just put all the metal parts together and put it in place you can't get the bolt through?
Old 04-01-2014, 09:42 PM   #28
KTS
KTS's Avatar
Drives: Vitz RS
No I cannot get the bolt through.
Klick
Old 04-01-2014, 09:48 PM   #29
Bluevitz-rs
Can you post a photo
Old 04-01-2014, 09:50 PM   #30
KTS
KTS's Avatar
Drives: Vitz RS
ok tomorrow I will try n take a photo showing it. I am thinking if I widen the holes and cut off the low tab it should fit up fine.
Old 04-02-2014, 02:56 PM   #31
KTS
KTS's Avatar
Drives: Vitz RS
Finally got them installed I had to widen the holes on the washers and they were a very difficult fit still. Thanks everyone who was assisting.
Old 04-02-2014, 03:04 PM   #32
Jason@SportsCar
Did you put them in the right direction?
Old 04-02-2014, 03:07 PM   #33
KTS
KTS's Avatar
Drives: Vitz RS
Really hope I did...fingers crossed. Will know when I go for an alignment tomorrow.
Klick
Old 04-02-2014, 04:08 PM   #34
Bluevitz-rs
Cool, well at least there in there.
Funny I'm installing my lowering springs again and my upper bearing on the drivers side strut is shot.... again. Oh well the replacement is way better than OE from Canadian tire. Uses a sealed bearing on the lower part compared to the OE being open with a stupid foam gasket.
Old 04-02-2014, 11:16 PM   #35
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
They are tight (for a reason) but no modifications are necessary to put the spacers in.
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 01-05-2017, 12:00 PM   #36
MugenRep
iQ innovator & researcher
MugenRep's Avatar
Drives: 2012 iQ
Update to this? Everything was installed correctly and no issues with the caster and did it increase?
MugenRep is offline   Reply With Quote
FS NorCal: Yaris/Prius C Partout: KW V3 / Whiteline / Greddy Ti-C / Etc B2FiNiTY Items for Sale by private party 25 04-25-2014 01:47 AM
Whiteline Polyurethane Bushing Review Monstro Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-15-2013 11:24 AM
alternator bushing JAMMED ! Siffleu DIY / Maintenance / Service 12 10-22-2010 10:12 AM
Gauging Interest: Whiteline Front/Back Adjustable Sway Bars RaptorRacing Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 12-15-2009 04:23 AM
NEW NST SS Shifter Bushing (AE86) NonStopTuning NonStopTuning 3 10-01-2007 03:12 PM
