#19 |
The tech that test drove the car with me in it tested for the mounts and said it is fine . Is he right , I
. Things are not turning out to well with work performed |
#20 |
#21 |
![]() ![]() Drives: '00 Echo Join Date: Mar 2014
I pulled a set of Iridiums out of my Echo, at 192k they were shot. I'd say 150-175k at best.
#22 |
Embracing Curves
Drives: '14 Prius Executive Join Date: Aug 2013
IIRC, that big gap is normal for plugs with iridium tips.
I have had a look at mine (68k km), and they almost looked the same, just a bit less of coal on them. However, I suspect american cars to run a bit richer than european ones. Might be due to different emission standards, I'll have to do some research in order to get clarity. Btw, how is your long term fuel trim?
I drive, therefore I am. |
| Location of Spark Plugs | KEVBD | DIY / Maintenance / Service | 7 | 02-03-2012 11:05 AM |
| Laser plugs? - Awesome | Altitude | Off-topic / Other Cars / Everything else Discussions | 1 | 04-24-2011 08:02 PM |
| article on spark plugs and the fit | kngrsll | Performance Modifications | 4 | 08-01-2009 11:50 PM |
| did autolite spark plugs screw up coil or coils ?? | la_scanner | DIY / Maintenance / Service | 20 | 04-09-2009 02:07 PM |
| Upgraded Spark Plugs For Boost | whooppee777 | Forced Induction Forum | 9 | 02-14-2009 01:53 PM |
