#163 |
![]() Drives: Yaris & Corolla Join Date: Aug 2012
#164 |
![]() ![]() Drives: 08 yaris Join Date: Nov 2010
cherry bomb
this one is a 2 inch pipe with a 2 inchcherry bomb turbo muffler, passes for a stock muffler. low tone unloaded . a good bit louder under load.
cost $24 at autozone and $44.00 to get the pipe bent and welded. I know it's not stainless or Unobtainium , but I've already started my next axle back , will post it in a few days. http://www.youtube.com/watch?v=fPtaWvaIkU0&list=UL |
#165 |
![]() ![]() ![]() ![]() Drives: 2010 Yaris S Join Date: Apr 2010
Anyone using the Apexi Bomber exhaust??
"In his heart a man plans his course, but the Lord determines his steps." Proverbs 16:9 |
#166 |
#167 |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
Sounds like beautiful music...
#168 |
Thanks man.
![]() I'm waiting on a couple prospects for my mid pipe replacement. should sound even most beastly when its all done. |
#169 |
![]() Drives: 05 Vitz Join Date: May 2013
Hey guys, figured I'd post here because I'm having a super hard time finding an axle back for my 05 echo (in Canada) anyone want to point in the right direction or sell me their exhaust? Lol thanks any info would be appreciated
#170 | |
![]() Drives: 2009 toyota yaris white Join Date: Jun 2013
#171 |
![]() ![]() Drives: 2007 tyota yaris 2 door hatchb Join Date: Jan 2010
inspection fail, texas
Hey fellas, I could use some help here.I have a 2007 yaris hatchback. 1.5 liter 5 speed. DC header, greedy full exhaust , no cat. And some little gadget box with wire that is suppose to trick ecu that it does have a cat engine light on. Code his for 0/2 sensor upstream. If I install a new 0/2 sensor my engine light should turn off right? I only have 15 days to fix this problem. And I'm on my eighth day.otherwise I will have to pay for another inspection. Please help. I didn't see another 0/2 sensor under there unless I missed it. Mechanic suggested I change both. 318.00 bucks for parts. :-(
#172 |
This is my very first post and hopefully not the last. I've been visiting yarisworld for a while occasionally until I finally bought my Yaris couple of months ago. I've been always a big V8 sedan guy but when I rented a Yaris in a road trip last I fell in love with it instantly, I don't know how to explain my feeling but wow, Huge difference from my Crown Vic and Aus Ford Falcon.
Anyway let's get to the topic . After a very long wait I finally got Tanabe Concept G Exhaust for my Yaris. Thanks to redyaris's post I managed to install it by myself. It was a relatively easy task but took me about 6 hours because the right wheel and one of the mufflers's spring bolts were stuck even with WD-40 and some hammering. here are the pictures: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I really love it. At first I thought it's a little bit loud and annoying especially on long drives. there was a moment when I regretted installing it and thought about reinstalling the OEM exhaust but now I Think I got used to it by now and I absolutely love it. I will upload a video as soon as it's uploaded on Youtube http://youtu.be/6OUqDz-pF2c |
#173 |
![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan Join Date: Sep 2006
I Drive a 129whp Yaris ;) |
#174 |
![]() ![]() Drives: 2010 5-door hatchback Join Date: Mar 2014
A question for you exhaust gurus:
A search of the forum turns up conflicting reports of a freer-flowing aftermarket exhaust system improving/hurting MPG. Some said it improves MPG and power, others have said it hurts MPG, but improves power. Either way, it seems a better exhaust will improve power and possibly affect MPG. I drive with a fairly light foot and mostly on the highway and average 43MPG most days. My Yaris is stock, but I am open to doing an aftermarket exhaust, provided it doesn't sound like bad rice and seriously hurt MPG. I wouldn't mind the few extra HP for a little help in the passing lane. If I go aftermarket, I plan to leave the intake stock and drop in a K&N filter. Maybe a header is fine, but I plan to leave the cats and resonator intact and possibly add an additional resonator after the stock one. There is a local custom exhaust shop that can do the work and I would ask them to follow the stock piping, but go up to a 2" pipe vs the stock 1.75" pipe (I understand the cats and resonator use a 2" pipe) and route it to the factory flange at the rear axle. From there, I'll probably bolt on a Tanabe Medalion or Nitto (plan to buy from Micro Image) as those two seem to be the quietest mufflers. How does that sound for an exhaust set-up? I am not expecting oh-my-god gains in HP or anything, but hope to have a little of both worlds: improved HP while being able to retain (or improve) MPG. |
#175 |
![]() ![]() ![]() Drives: Yaris sedan Join Date: Jan 2009
que porqueria Angelo jajajajajajaja
#176 | |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
A typical muffler shop will only crush-bend tubing. So their 2" tubing is typically smaller in the bends then your stock midpipe. So the only thing your getting is no improvement in exhaust flow and lower quality tubing that will rust out eventually. I suggest a rear section exhaust for some power and sound and not throwing away all your mpg. These motors really love a full exhaust so real gains in power can be realized
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#177 | |
#178 |
![]() ![]() Drives: 2013 3Dr Super white Join Date: Apr 2012
#179 |
Fugitive
Drives: 2007 Yaris 4 Door Hatch Join Date: Jul 2014
what is the basic function of these cats ?
please suggest what option from below should i go, for the maximum HP gains .. regardless of fuel economy .. 1: remove both cats and resonator and put a straight down pipe of 2" or 2.25" ( please suggest which is better 2" or 2.25" ) till the end ... 2: keep the 1st cat and remove the second cat and the resonator and put a straight down pipe till the end ... 3: keep both cats and just remove the resonator and put a straight down pipe till the end ... 4: keep both cats and resonator just put a straight down pipe after the resonator till the end ... 5: remove both cats just keep the resonator and put a straight down pipe till the end ... |
#180 |
![]() ![]() ![]() ![]() ![]() Drives: Toyota Yaris Sedan 09 STD Join Date: May 2009
Remove both cats with 2" exhaust and magnaflow freeflow muffler
| DIY: Installing Greddy TI-C Exhaust System | redyaris | DIY / Maintenance / Service | 13 | 08-01-2009 05:05 AM |
| GReddy prototype = Free Exhaust! | Chris_Lum | California | 30 | 02-27-2007 11:13 PM |
| Why is DTM exhaust thread closed? | gr8yaris | Performance Modifications | 4 | 01-13-2007 12:01 PM |
| Fujitsubo Exhaust!! | MC-BPT | Sponsors Classifieds Area | 17 | 11-16-2006 11:36 AM |
| Toyota Performance Exhaust for Yaris HB | bigsky2 | Performance Modifications | 16 | 06-02-2006 11:21 AM |
