#109 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Im pulling together to get some funds set aside for this. Just dropped my trans off for the Malibu to get rebuilt, sent the cam and lifters to get WPC treated as well. Too many projects!
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#110 | |
play every day
Greg |
#111 | |
play every day
There are still two available from this production run. And if there is still any interest after this run sells out, I can always have another run machined. Greg |
#112 |
#113 |
My local Chevron said they switched to summer blend, but didn't say when they did.
#114 | |
play every day
Greg |
#115 |
play every day
I'm down to the last spacer now...
#116 |
![]() ![]() ![]() Drives: 2012 Grey Toyota Yaris SE Join Date: Dec 2011
Greg, is there anyway you can hold the last one for me? I'm just waiting to finish my clinicals and waiting for the hospital to hire me which is very soon! anyway i can put a down payment?
Upgrades: AFE SRI. Tanabe Touring Medalion Axleback exhaust. Micro Image OEM Sized Lightweight Pulley. DC Sports header. |
#117 | |
play every day
Don't worry, man... ![]() Even if the last one sells out before you're ready to buy, I should be able to have a few more made within a month or so. The worst that could happen is that you might need to wait for just a little while. Greg |
#118 |
Greg you are the man!!!! Once my first big check from the hospital arrives, i'm using it to buy a tooter!!!
#119 |
i think i'm going to buy this and the trd rear sway bar and hold off on the dc sports header haha!
#120 |
is anybody using this tooter spacer with an automatic tranny?
#121 |
play every day
The one that shipped today is going to a guy with an auto. So as far as I know, he'll be the first to experiment with it. My best guess is that an auto trans will shift at slightly lower rpms because the stronger intake manifold vacuum signal will indicate less engine load, but I have no idea exactly what will happen. With my manual it easily short shifts at 2,000 rpms, and pulls in the next higher gear from under 2,000 without lugging the engine. That helps the gas mileage not needing to rev the engine as much in normal driving. Now if I could just get my wife not to rev the engine so much!
![]() Greg Last edited by tooter; 06-12-2014 at 12:35 PM. |
#122 |
![]() ![]() Drives: 2010 5-door hatchback Join Date: Mar 2014
That would be me. Unfortunately, my Yaris lacks a tach, but I do have a ScanGaugeII. I'll try to see if I can't keep track of when the tranny shifts and compare that to after the spacer install. I'm hoping the tranny will keep up with any torque gains lower in the RPM range and shift accordingly. I hope this mod would end up giving me a little more low end power and squeeze out another MPG or two. I'll post up my findings after driving around with it a little.
#123 |
play every day
You might be able to tell any difference of when the transmission shifts by feel. You already kind of know when it's going to shift according to how much you press on the gas pedal, and how much engine load there is such as grades. Gas mileage is a good indicator as it's sensitive enough to respond to more subtle factors.
It'll be really interesting to see what happens as this is uncharted waters. So if after driving with the spacer you feel that the benefits aren't worth the cost, please feel free to return it undamaged and I'll be happy give you your money back. ![]() Greg |
#124 |
That is very generous of you, Greg! I guess we will see how it goes and I hope my experiment with it will be of some use to you. Wish I had a manual tranny, but the wife just doesn't want to learn how to drive one...
#125 |
play every day
I'm still trying to get my wife to rev the engine less so we can get better gas mileage. It's a lost cause.
![]() Greg |
#126 |
Finally got the Tooter spacer installed today. Took me a while to get the time needed to do the install and I had to do a couple runs to the hardware shop for some tools. All together, the install was fairly straightforward and simple. I had to lengthen a couple hoses, but the other hoses seemed to have enough slack to make the move. I used the stock airbox without any issues. Greg has an excellent kit put together and the spacer is very well made - a perfect fit.
![]() ![]() ![]() I let the battery remain disconnected during the install, which took about an hour. I had to remove the bolts that hold the coolant fill cap section to the throttle body and offset it in order to make the move. I was able to reconnect the fill cap section to the original mount using just one screw and made sure nothing was rubbing the hoses. ![]() With the decorative engine cover back on, it looks virtually stock - especially with the stock airbox. Despite being only held on with 2 screws instead of the usual 4, the cover didn't rattle and the front edge was actually supported by the flange of the intake manifold. ![]() Driving the car after the install was pretty much the same as before. I have an auto tranny and there were a few instances where the shifts came late at lower rpms. The tranny hung in the gear a little longer than what seemed like usual, but it stopped doing that after I got out of the residential roads and started going 50mph. I did not notice any change in how the car drove. I did test out the acceleration on highway onramps at WOT and it almost seemed like the car got up to highways speeds a tad faster than before, but then again, it could be the placebo effect taking hold. No info on fuel mileage yet since this is the first drive with it, but I can update this thread with my MPG with auto tranny once I have a few fill-ups done. |
| tooter's manifold adventure... | tooter | Performance Modifications | 1465 | 07-31-2014 09:11 PM |
| FS : GT2560R Turbo + Manifold | Parmas | Items for Sale by private party | 0 | 08-24-2012 09:35 AM |
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 02:09 AM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 07:52 AM |
