![]() ![]() ![]() Drives: 2002 JDM Vitz 1.3 Join Date: Feb 2013
Throttle Body Swap Fail, help needed
Hey guys,
I have a 1300cc 2NZ-FE with a tiny 3 bolt throttle body. I recently attempted to upgrade it to a 51mm TB from a 1.8 7AFE corolla engine. http://www.yarisworld.com/forums/showthread.php?t=51176 Unfortunately it didn't fit, the vacuum point didn't line up and the stock bolts are too short My next attempt to upgrade the throttle body relies on one you awesome fellas on the forums. The stock US Yaris intake manifold uses 4 bolt throttle bodies, it should also mount directly to my engine. I would like to know if anyone would be willing to sell me the stock intake manifold. It would be greatly appreciated. -Justin
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete Follow me on Instagram: instagram.com/itzkingjustin |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
Hey Justin,
Sorry, man... ![]() My CNC engineer had told me two months for a throttle body adaptor, but now he isn't available to do any of my tooter stuff. He's totally occupied working on really big projects now so I'm out of luck. That's a better idea just to get a stock intake manifold. It would be way cheaper than an adaptor. ![]() Greg |
Its all good Greg, trial and error is key to moving forward.
The hardest part will be finding a used manifold, I haven't seen any on eBay.
So as per your other thread, we said the 1ZZ throttle body works and you get one from a 7AFE
![]() Um, why? |
? OP have a 2002, which have a cabled TB.
I have a 2005, which also has a cable TB and so does the corolla before '03 with 1ZZ
OH.. interesting, cuz i kept reading about 1zz DBW TB...
Just like the 1NZ went from cable to wires, as so did the 1ZZ.
![]() ![]() ![]() ![]() Drives: 2013 Yaris Join Date: Oct 2011
I might be able to get my hands on a stock intake manifold for you. I had an extra and a friend was going to use it on his XB, but he never did. I'll ask him if he still has it.
#10 | |
Thanks much, I'd really appreciate it
#12 | |
#14 |
Thanks, it seems I have the 1zz throttle body after all but as suggested in that thread, I'll have to do some modding.
Thanks
#15 |
did you get this working?
#16 |
Sadly I didn't, got some longer bolts, made the sandwich plate, installed everything and had a massive vacuum leak between the intake manifold and the tb.
I don't know but it seems the 2NZ-FE manifold is way smaller . I don't even think this mod makes sense on the stock manifold as the entry point on the manifold itself is about 35mm I'm going to try and source a 1NZ intake manifold or port out the stock one I have. Trial and error is necessary, hopefully I'm helping someone who might attempt this as well
#17 | |
play every day
Greg |
#18 | |
2ZR swap. DO IT! Ask how!
It took almost a year (on the calendar) to get all of the custom parts purchased and fabricated, and three separate tries to machine the adapter. I could repeat the process in about a week if I needed to, but the first attempt always takes me a long time. The next change will be to find and remove the new bottleneck, but that's probably going to require custom fabrication of cast or welded parts. |
| wtb stock throttle body , cheap | blacksandiegovitz | Willing to Buy by private party | 0 | 09-21-2012 10:32 PM |
| THROTTLE BODY SWAP NO CEL!!!! | kou | Performance Modifications | 53 | 02-01-2011 04:01 PM |
| FS- 1ZZ Throttle Body, Spacer, NST SSK | MGargano | Items for Sale by private party | 9 | 09-01-2010 08:48 PM |
| Toyota Throttle Body Spacer: the Best Fuel-Saving Device | davidmills | Performance Modifications | 1 | 07-01-2007 11:38 PM |
| toyotafest 2007 | esquiva | Photo-Video-Media Gallery | 36 | 05-15-2007 12:03 PM |
