Old 06-20-2010, 05:19 PM   #1
kou
Drives: 08 lb
THROTTLE BODY SWAP NO CEL!!!!
So i did the swap without getting a cel ever. THANK YOU jkuchta for the info.I ordered a new intake manifold, a yaris and a corrola throttle body.Step one was to fill in all the cavaties on the manifold with JB weld then port the opening as much as i could. swapped the chips over on the throttle bodies and removed the epoxy from the idle adjustment screw,then switched everthing over, did a pre adjustment on the idle screw and made a paper gasket which is siliconed in place.
Old 06-20-2010, 05:31 PM   #2
how much were you able to open up the stock manifold?
Old 06-20-2010, 05:36 PM   #3
kou
Drives: 08 lb
I ported the top to about 2.4" then i tappered down as much as i could, the plastic is thinner the further you go.the factory opening is 1.75".
Old 06-20-2010, 05:49 PM   #4
not too shabby
notice a difference then?
Old 06-20-2010, 06:15 PM   #5
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Nice and clean. Very good job!
I opted for a custom adapter instead of porting the IM. How much did the IM cost? Just curious.
Old 06-20-2010, 06:15 PM   #6
kou
Drives: 08 lb
There is a difference at all rpms but more after 2250rpms.more engine power with the ac on which is a big plus. my ASStermater says more tourqe than hp.definetly worth the $250 in total spent.
Old 06-20-2010, 06:16 PM   #7
kou
Drives: 08 lb
Thanks tk-421.manifold cost $113
Old 06-20-2010, 07:08 PM   #8
1NZYaris1
1NZYaris1's Avatar
Wow that is nice
this is one Mod i would love too do , but am affraid to do as it might not
be as simple on the 2NZ-FE.
Enjoy and congrates
Old 06-20-2010, 07:13 PM   #9
Wow that is nice
Enjoy and congrates
should be the same...only different item on the 2nz is the pistons/rods (and therefore the displacement)?
Old 06-20-2010, 08:05 PM   #10
kou
Drives: 08 lb
Wow that is nice
Enjoy and congrates
Thanks i am enjoying ever minute.
Old 06-20-2010, 09:50 PM   #11
nicely done. I've always thought that this mod, done carefully, is a good one.
Old 06-20-2010, 10:40 PM   #12
kou
Drives: 08 lb
Thanks, definitely can't rush this one.
Old 06-21-2010, 10:26 AM   #13
d1nzfe
Drives: 1NZ-FE
what do u fill up those 'holes' with? the purpose to 'strengthen' the frame for porting?
d1nzfe is offline   Reply With Quote
Old 06-21-2010, 11:34 AM   #14
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
NICE WORK, very good thinking on how to get it done, as long as you let the JBWeld cure and it stays that is a nice for DIYers. Just hope nothing ever happens where a chunk might come off of that and go into the engine
Old 06-21-2010, 12:49 PM   #15
kou
Drives: 08 lb
Thanks Nexus.I am not to worried about the JB weld it's now a solid ring.Any way if something did happen engines are pretty cheap.
Old 06-21-2010, 12:54 PM   #16
kou
Drives: 08 lb
I used JBweld the slow curing type.Mainly to make a flat mating surface for the throttle body.Because of the intake manifold design after porting you have to put JBweld on the inside to get a smoother slope.
Old 06-22-2010, 12:33 PM   #17
Nexus1155
Drives: Audi
Drive a full cycle, usually 80miles on most ECU's and let us know if there are any CEL then? I would love to do this.
Old 06-22-2010, 01:06 PM   #18
YarisSedan
Drives: 08 Yaris Sedan
Wow very nice. If your gona do something do it right. For the price of the intake manifold its not that bad.
1ZZ-FE throttle body crxgames Items for Sale by private party 1 04-27-2009 05:19 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
DIY: Tricking ECU Throttle Body Relearning gwasabi DIY / Maintenance / Service 2 04-03-2009 07:02 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
