Old 07-25-2014, 01:20 PM   #1
yaris9876
Drives: yaris hatch 07 640K original m
hatch door
the latch in my 07 hatch is stuck. totally. I tried spraying wd40 from both sides but still wont turn. How can I get it from the inside??? There must be a way..
yaris9876 is offline   Reply With Quote
Old 07-25-2014, 01:36 PM   #2
Just pop the little rectangular cover directly behind it, on the inside of the hatch. Once you do you will see the lever that the latch pushes on. Simply push it to the side with you finger and the hatch will pop open.
Old 07-26-2014, 11:37 PM   #3
yaris9876
how would you clean it so it doesnt do that again??
Old 07-26-2014, 11:40 PM   #4
You can remove the one bolt on the inside of the hatch to remove the entire lock assembly to clean and lube it. If the latch assembly is the problem, you can remove that from the bottom edge of the hatch and do the same.
Old 07-27-2014, 04:43 PM   #5
yaris9876
I see how it works now... but on mine the white plastic thing wont go in the unlock position.
I can leave it unlocked and lock it but the key just cant force it over to unlock
.... I lubed it well with wd40 but
still wont go... Would it be a big deal to replace the whole key drum and plastic thing with an aftermarket assembly that would fit in there??The drum seems to be held in my 2 bolts..not 1
Old 07-27-2014, 07:30 PM   #6
You can replace it, but unless you have a locksmith modify the existing one you will need a separate key for the hatch. I have a couple of spare ones if you need one, as I changed two of mine over to using the Scion IQ hatch knob with switch and have it electrically actuated:
http://www.yarisworld.com/forums/showthread.php?t=39677
Also, try a different key, if you have a spare, as it may be that your key has worn too much for the hatch lock.
DIY: Replacing 2-Door Liftback Door Panel Fabric redyaris DIY / Maintenance / Service 25 06-25-2024 02:24 AM
3 door vs 5 door hatch bentjazz General Yaris / Vitz Discussion 48 03-13-2014 06:17 PM
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-05-2011 12:56 AM
rear hatch for 08 yaris 5 door nb85351 Willing to Buy by private party 1 09-05-2010 08:12 PM
DIY: Changing Factory Door Handles and Lock Cover redyaris DIY / Maintenance / Service 10 05-19-2007 06:55 PM
