#145 |
Yup, agree to all. I re-edit my previous post to fix error. I meant to say RPM was lowered but fuel consumption hasnt changed still 0.125/hr.
Doing the install did give me a chance to see how clean the intake valves were, there's some light oil that a catch can would take care of. Edit: After driving today looks like ecu is learning. Idle fuel consumption warmed up is now 0.116 gal/hr and subsequent using a catch can lowers it do 0.106 gal/hr. Edit 2: So i was stuck in stop and go traffic, and was able to use 2nd gear to keep the car crawling forward using no throttle at all, as long as i was not completely stopped. / 5th gear hill climb on a particular hwy of mine is also doable now, I normally have to go down to 4th. These two things helped me get 49 mpg on a 14.4 mile run, where 41% was city and 3 miles were that stop/go traffic.
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 Last edited by ezhacker1; 08-02-2014 at 02:24 AM. |
#146 |
play every day
Yeah, the car creeps really good...
![]() I also have fun in traffic doing standing starts in first just with the clutch and no gas. It even does it on a slight incline with no bucking or stalling. That's really outstanding mileage results! Greg |
#147 |
If my wheels didnt weigh 43lb, i would be able to creep better lol. I might switch back to my 28lb Team Dynamics 14s.
I havent had a chance to dyno the car, but another evidence of the torque curve moved is seen in how DFCO now cuts off at 750rpm vs stock, which i believe is 1000 or 1100, so there's quite a change.
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 Last edited by ezhacker1; 08-16-2014 at 03:43 AM. |
#148 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Woohoo!
![]() Hoping to base line the car tomorrow then test the spacer tuesday night
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#149 |
![]() Drives: Toyota Premio NZT240 Join Date: Jul 2014
Slightly off topic, hey tooter, what kinds of gains did you see with that BLOX filter and stock intake manifold?
#150 |
Obsessed with 1.5L
Installed it...YES!
Wow...part throttle performance is vastly improved. Feels like a 2 liter motor down low
#151 |
Obsessed with 1.5L
81k...looks like i need a catch can. Will properly address that soon.
![]() ![]() I just cannot believe the difference in the low rpm torque I gained
| tooter's manifold adventure... | tooter | Performance Modifications | 1465 | 07-31-2014 08:11 PM |
| FS : GT2560R Turbo + Manifold | Parmas | Items for Sale by private party | 0 | 08-24-2012 08:35 AM |
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
