Old 11-01-2008, 03:36 PM   #37
TheSilkySmooth
TheSilkySmooth's Avatar
Hey Bike - does that wiring kit help smooth out the engine- My sisters 3 dr is like Jekl and Hyde - some days smooth and other it wont get out of its =way and runs like there is spark scatter or some 'puter problem real buzzy and no pull. Whats up with that?
- S's Bro
Old 11-01-2008, 05:20 PM   #38
bikegerm
bikegerm's Avatar
Drives: 2007 Meteor LB
The ground kit made a big difference in the stereo system. It has no hums or buzzes at all. As for the performance, I've never had any problems with sputters. My plugs fire smooth all the time, even in the morning when it's cold. Don't know if it's related to the ground kit.... By the way, your avatar is looks like a heartbreaker !!
Randy LeRoy
www.airshowmastering.com
randy@airshowmastering.com
bikegerm is offline   Reply With Quote
Old 11-02-2008, 06:10 AM   #39
andries
aka Jack Wolfskin
Drives: Yaris
Send a message via MSN to andries
Originally Posted by CASTREX View Post
You are cold....!
But yeah, the front strut doesn't do much for the car.
It does look cool tough!
Originally Posted by largeorangefont View Post
The bar is usless, and does not need to be retentioned.
Therefore race- and rallycars have one. For more weight
andries is offline   Reply With Quote
Old 11-02-2008, 08:00 AM   #40
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
Race/rally cars drive in tougher terrain and higher speeds than road cars, with upgraded suspension bushings, harder and/or longer travel suspension with grippy soft-compound tires that impose more stress on the chassis.
You don't need it for the local grocery shop special stage.
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 11-02-2008, 08:14 AM   #41
andries
aka Jack Wolfskin
Drives: Yaris
Oke, but sometimes I drive on the circuit with my Yaris and often I drive on mountain roads in Germany with many sharp bends. A strut tower bar gives a noticeably better cornering behavior.
So the tower bar is a good addition to the chassis of the Yaris, not all of the above but also for the "sporty driver".
Old 11-02-2008, 06:36 PM   #42
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Is not that the front strut bars don't do nothing... they just don't do nothing on a Yaris...
This is due to the chasis configuration of the Yaris.
Even if you are driving at the track...
You will have to install a full racing suspension in order to receive any benefit from a this bar on the Yaris.
There are a lot of other car that can use the benefit of a front strut bar even for street use. The Yaris is not one of those.
On the other side the rear sway bar does alot for the car.
I have not use the other under bracing available for the car... so I can not talk about those.
Old 11-10-2008, 12:16 PM   #43
TheSilkySmooth
I'll pimp out sis if you help her change the oil - I'm tired of working on her car for her.
Old 11-10-2008, 12:22 PM   #44
TheSilkySmooth
To prove that you woulld have to put a strain guage on the brace to see what loading it is getting under side load - also you can statically load the lower wheel (with hydraulic/ratchet puller and come-a-long and see what moves. we'd do this for race setup - on the street just buy the part and feel the diff, if any. The car still def needs firmer bushings - the front wallows terribly on tight radius.
Old 11-10-2008, 12:45 PM   #45
andries
aka Jack Wolfskin
Drives: Yaris
Originally Posted by rnelson View Post
Is there anyway to install Tanabe strut tower without removing all the wipers and the splash shields? Any tips on installation?
I removed nothing. Just jack up the car and with two people to fit the bolts and nuts.
Old 11-10-2008, 05:26 PM   #46
Never Enough
Never Enough's Avatar
Drives: Jbody
Nice addition under the hood!
Never Enough is offline   Reply With Quote
Old 11-10-2008, 07:07 PM   #47
Thej3sta2
Thej3sta2's Avatar
Drives: Soon to be LFA
very nice i want one so bad
Thej3sta2 is offline   Reply With Quote
Old 04-29-2009, 01:07 PM   #48
SEVEN
Drives: 07' HB Black
Does TRD springs and KYB shocks count as full racing suspension?? If not, just say that the STRUT BAR makes a lot of difference in the handling so I can sleep at night PLEASE
When life passes you by ... dowshift
SEVEN is offline   Reply With Quote
Old 04-29-2009, 01:40 PM   #49
Mouse
Drives: 2007 MX5
Would the yaris benefit from a 3-point front strut bar?
If so, why has one not been developed yet?
Mouse is offline   Reply With Quote
Old 04-29-2009, 01:52 PM   #50
YarisSedan
Drives: 08 Yaris Sedan
I noticed a difference with mine. Especially on hard turns or really quick lane changes. Also was able to install mine without lifting car up but was really cramped fitting hand up there.
Old 11-09-2012, 06:13 AM   #51
speed1
Drives: vitz rs
They go shopping using front bar.
They go driving using rear.
speed1 is offline   Reply With Quote
Old 08-08-2014, 06:14 PM   #52
aspro
Cool tanabe strut tower bar installed pics
Just finished installing mine. Nice product with nice fittings and hardware. Simple install. Felt a difference in steering input and it seems as if it let's you enter harder into corners and allows some room for mistakes. Not a huge difference though. Probably would have passed on it and put the money towards getting Garms intake manifold. Definitely looks good though.
aspro is offline   Reply With Quote
Old 08-09-2014, 11:23 PM   #53
Looks good!
Old 08-10-2014, 02:16 AM   #54
268i
Drives: 06' Yaris 1.3l
I'm thinking of getting one but not unsure on how to install. would you mind briefly doing over the details? Thanks
268i is offline   Reply With Quote
Installed the Tanabe Strut bar but had to remove my ground wire kit.. vacantj Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-01-2007 01:56 PM
**NEW ITEM** Tanabe Sustec Front strut bars C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 04-27-2007 09:54 PM
