Old 08-26-2014, 10:35 AM   #1
How to turn a Yaris into a Tacoma
I recently sold my Tacoma, as the only thing I really used it for was my weekly trip to the recycling center. I don't like the idea of carrying trash or recyclables inside my car, so I decided to turn my Yaris into a proper Tacoma replacement.
I found a hitch rack that would perfectly fit my two cans and then added a Curt hitch to my Yaris to mount it. I purchased the 11050 Curt hitch and the 18145 cargo carrier from thehitchstore.com. I was very impressed with how simple the Curt hitch was to install and how hidden it is. Installation just required releasing the two bottom tabs from the bumper, slipping the hitch up under the hitch cover, and mounting it to the two tie down points with three bolts on each side. Everything was easily accessible and although I had the car on my lift, it could easily have been done on the driveway.
Old 08-26-2014, 11:00 AM   #2
NEexpat
Drives: 2009, auto, 4dr LB
Ha! Nice.
Another addition from the skunk works in CT.
Ummmmmm - "Trashy?"
NEexpat is offline   Reply With Quote
Old 08-26-2014, 11:01 AM   #3
firebird1999us
firebird1999us's Avatar
Drives: 2003 Mach 1
NICE!
firebird1999us is offline   Reply With Quote
Old 08-26-2014, 01:59 PM   #4
bronsin
bronsin's Avatar
Always wanted one of those!
Not to cause trouble but....
1) How much weight is safe to haul? The car is FWD and youve got all that weight on the opposit end of the car.
2) Wouldnt that thing interfere with accessing the hatch? How easy to R and R?
Thanks!
Old 08-26-2014, 02:13 PM   #5
Thanks!
Good questions!
1. The rack is rated for 500 lbs. My cans fully loaded would not likely ever exceed 150lbs combined. If I (~160 lbs) jump up and down on the rack (besides looking quite silly) I find that the rear squats and the front does not seem to be effected.
2. It does interfere with the hatch when the cans are on it. With objects up to 17" tall on the rack the hatch will open completely.
By R and R I think you mean put it and take it off. If that is the case, I just slide it into the receiver and slip the receiver pin in (literally seconds on and off). Because the receiver is under the bumper I have to reach through the rack to do so. If the rack had a solid or mesh floor, I would have to reach around from the side of the rack to deal with the receiver pin.
It does block visibility of my rear license plate. Thus far (four runs with it) I have not been stopped and I have passed by police cars on the way. The tail lights are still fully visible as the rack is just a tad narrower than the space between them.
Old 08-26-2014, 02:23 PM   #6
I purchased a hitch basket 3 years ago so that I could use the Yaris for our annual family vacation to New Brunswick. So far I have logged approx 9500 kms across 3 provinces with the plate obscured by a large duffel bag in the basket. Have not yet drawn the attention of the various law enforcement units I encounter throughout the journey.
So far mine has been used to haul;
- luggage
- gas cans
- pool chlorine
- a tree
Old 08-26-2014, 04:45 PM   #7
nookandcrannycar
Good questions!
Absolutely fantastic!
2-3 questions:
Which size BRUTE cans are you using? (if 50 gallon, then the next question is moot)
If your BRUTE cans are the 44 gallon ones or smaller, do you know the largest size can that will fit on that basket?
Which strap w/hooks are you using?
Old 08-26-2014, 05:46 PM   #8
2-3 questions:
My Brutes are 32 gallon and they fit in like a glove. The inside dimensions of the rack are 18" x 46.5", and the 32 gallon Brute is 18" at the bottom, so they slide in and fit snugly. I really just use the strap to hold the covers from popping off.
For the strap, I added two eye bolts in place of two of the screws on the carrier, to make it easier to hook on. I started off with one of the ratcheting straps (that I trimmed the excess off to make it perfect for the two cans). I found slipping the end into the ratchet a hassle, so I instead switched to a motor cycle strap. It was about 18" too short though, so I sacrificed a second one and sewed 18" of it into the other one to make it fit perfectly.
Old 08-26-2014, 07:06 PM   #9
nookandcrannycar
Thanks so much for this ^^^^^ post and this thread! This is really going to help me in California re temporarily moving some things a relatively short distance (about 20 miles), taking some things to be recycled or donated, and taking some other things to the dump/transfer station. I imagine it won't matter which Yaris I take to California as (according to thehitchstore.com website) that hitch will also fit on a 2014 Yaris (as long as it is not an SE). I'll purchase the BRUTEs in California (right before I need them)....they're listed as in stock at some Home Depot stores around here, so I imagine the same is probably the case in California.
I have a friend who lives in one of the colder (during the winter) East Bay (SF Bay Area) suburbs. IIRC, his house is between 3000-3500sf (2 story). He has a pellet stove insert in the fireplace in his living room, and has sworn by it for quite a few years. He's had me stand in every room to illustate to me how effective it is . He'd drool if he saw the number of bags of pellets you've got stored (6 tons total, IIRC from another post) . His garage is big enough...he just can't get his beloved wife to get on the same page he is (re neatness and organization) in order to clear enough room. They're originally from Chicago (suburbs)....so, very in touch with 'keeping warm in the most efficient manner possible'.
Old 08-26-2014, 08:12 PM   #10
I have a friend who lives in one of the colder (during the winter) East Bay (SF Bay Area) suburbs. IIRC, his house is between 3000-3500sf (2 story). He has a pellet stove insert in the fireplace in his living room, and has sworn by it for quite a few years. He's had me stand in every room to illustate to me how effective it is . He'd drool if he saw the number of bags of pellets you've got stored . His garage is big enough...he just can't get his beloved wife to get on the same page he is (re neatness and organization) in order to clear enough room. They're originally from Chicago (suburbs)....so, very in touch with 'keeping warm in the most efficient manner possible'.
The pellet stove really is amazing. We bought it to make use of the fireplace and to have a place to warm the buns. In the first couple of weeks of using it from when we woke up until we went to bed, I noticed a significant drop in heating oil consumption, so we started running it 24 hours/day. In that mode I found that 1 ton of pellets equaled a 275 gallon tank of oil for 1/4 the cost.
Last winter was super cold and long and we burnt just over 5 tons of pellets. We ran out towards the end of heating season and had to scramble to find a few bags here and there. This year we bought six tons to make sure we don't have to do that again.
Old 08-26-2014, 08:34 PM   #11
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
My concern with this kind of setup is the torsional (roll moment) loads that it can generate on the receiver, and the tongue weight. I went with the internal solution and found a nice big rubbermaid bin that fits in the cargo area with the rear seats slid forward.
Old 08-26-2014, 08:37 PM   #12
I was a bit concerned about that myself, but thus far I am amazed as to how little it moves with the car in motion.
Old 08-26-2014, 09:29 PM   #13
nookandcrannycar
I can see multiple future uses (for me) re what Scott has pulled together . However, I think your solution is ALSO great for a temporary need in California (use both) ......but I only need one of them...not eight . Do you know of any retail STORE (that has a location in TX, NM, AZ or CA...or even in Las Vegas) that sells them individually, not by the 8 pack ?
Old 08-26-2014, 10:02 PM   #14
CrankyOldMan
Oh, that's just the first pic I found of it. I bought mine at a local hardware store a few years back, so I don't know if it's even in production anymore.
Old 08-26-2014, 10:16 PM   #15
nookandcrannycar
Thanks. It is, I just haven't located anything smaller than an eight pack. I'll check a few stores in California when the time comes.
Old 08-27-2014, 03:48 AM   #16
Astroman
Modded Moderator
Astroman's Avatar
Nice cans you got there
Old 09-05-2014, 02:13 PM   #17
And, here's another advantage of using the Yaris in place of the Tacoma: FREE dump runs.
I pulled out a set of built-in bookshelves recently and needed to dispose of them. I decided to load them into the back of the Yaris, rather than using the carrier, as it was a lot of pieces of wood. We get charged by volume to dispose of items other than recyclables or household trash at our recycling center, and normally a run like this would run somewhere between $25 and $40 depending on which dump dude looked at the truck and estimated the volume. With my short bed Tacoma, this would have looked like a lot of material, so chances are that I would have gotten dinged the $40.
With the Yaris, I tell the dump dude that I have a book shelf in the back to dispose of and he looks at the car and says "In the back of that little thing?". I say yes and he says "It can't be very big to fit in there. No charge". Little did he realize that this is what was back there:
Old 09-06-2014, 08:22 AM   #18
bronsin
bronsin's Avatar
We get charged by volume to dispose of items other than recyclables or household trash at our recycling center, and normally a run like this would run somewhere between $25 and $40 depending on which dump dude looked at the truck and estimated the volume. Attachment 54039
$40 TO THROW SOMETHING OUT!!!!
First they cut peoples heads off on TV and now THIS!
(could this be the doing of the terrorists?)
carrier, hitch
Toyota Hybrid R Shows Its Yaris Roots MadMax General Yaris / Vitz Discussion 0 10-10-2013 06:14 PM
How to turn ON Yaris Maintenance Required light? JohnnyRockets DIY / Maintenance / Service 11 12-14-2012 10:36 AM
Ohio Yarii owners: Turn in Concepts needs a Yaris to measure! schleppy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 04-17-2009 04:20 PM
