Old 07-31-2014, 07:34 PM   #145
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
Yup, agree to all. I re-edit my previous post to fix error. I meant to say RPM was lowered but fuel consumption hasnt changed still 0.125/hr.
Doing the install did give me a chance to see how clean the intake valves were, there's some light oil that a catch can would take care of.
Edit:
After driving today looks like ecu is learning. Idle fuel consumption warmed up is now 0.116 gal/hr and subsequent using a catch can lowers it do 0.106 gal/hr.
Edit 2:
So i was stuck in stop and go traffic, and was able to use 2nd gear to keep the car crawling forward using no throttle at all, as long as i was not completely stopped. / 5th gear hill climb on a particular hwy of mine is also doable now, I normally have to go down to 4th. These two things helped me get 49 mpg on a 14.4 mile run, where 41% was city and 3 miles were that stop/go traffic.
Check out my Build thread:
Old 08-05-2014, 10:13 PM   #146
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Yeah, the car creeps really good...
I also have fun in traffic doing standing starts in first just with the clutch and no gas. It even does it on a slight incline with no bucking or stalling.
That's really outstanding mileage results! I'm glad you're able to record yours. I'll never know what mine can get because my wife drives the car more than I do...
Greg
Old 08-05-2014, 10:19 PM   #147
ezhacker1
ezhacker1's Avatar
If my wheels didnt weigh 43lb, i would be able to creep better lol. I might switch back to my 28lb Team Dynamics 14s.
I havent had a chance to dyno the car, but another evidence of the torque curve moved is seen in how DFCO now cuts off at 750rpm vs stock, which i believe is 1000 or 1100, so there's quite a change.
Old 08-29-2014, 01:52 PM   #148
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Woohoo!
Hoping to base line the car tomorrow then test the spacer tuesday night
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 08-29-2014, 01:56 PM   #149
Rakin
Drives: Toyota Premio NZT240
Slightly off topic, hey tooter, what kinds of gains did you see with that BLOX filter and stock intake manifold?
Rakin is offline   Reply With Quote
Old 08-30-2014, 04:58 PM   #150
malibuguy
Obsessed with 1.5L
Installed it...YES!
Wow...part throttle performance is vastly improved. Feels like a 2 liter motor down low
-96 Tercel 4dr
Old 08-31-2014, 03:01 PM   #151
malibuguy
Obsessed with 1.5L
81k...looks like i need a catch can. Will properly address that soon.
I just cannot believe the difference in the low rpm torque I gained
-96 Tercel 4dr
tooter's manifold adventure... tooter Performance Modifications 1465 07-31-2014 08:11 PM
FS : GT2560R Turbo + Manifold Parmas Items for Sale by private party 0 08-24-2012 08:35 AM
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
