Old 07-13-2014, 09:56 PM   #181
salmanghiyas
Fugitive
Drives: 2007 Yaris 4 Door Hatch
Originally Posted by mario98c View Post
Remove both cats with 2" exhaust and magnaflow freeflow muffler
u mean from the header neck .. i put a 2" pipe then in the middle put a resonator .. and at the end use the magnaflow muffler ?
salmanghiyas is offline   Reply With Quote
Old 07-13-2014, 09:57 PM   #182
mario98c
mario98c's Avatar
That's correct.
Old 07-13-2014, 10:00 PM   #183
salmanghiyas
Fugitive
That's correct.
Awrite :)
and what roughly expected HP gains i would get ...
Old 07-13-2014, 10:05 PM   #184
mario98c
mario98c's Avatar
I can't tell you exact dyno numbers because I never visited a dyno after installing the exhaust but you will definitely feel the difference in acceleration. You will not regret doing it.
Old 07-13-2014, 10:11 PM   #185
salmanghiyas
Fugitive
ohkhay ...
if i use 2 resonators in the middle .. just for lowering exhaust sound .. would it effect the performance ?
Old 07-13-2014, 10:18 PM   #186
mario98c
mario98c's Avatar
ohkhay ...
I don't think so but with one resonator the car is quiet enough that it won't bother you cruising at normal speed.
Old 07-13-2014, 10:21 PM   #187
mario98c
mario98c's Avatar
Here is a video of my car with 2" exhaust, magnaflow imitation muffler(the original magnaflow should sound better) and a magnaflow 2" glasspack as a resonator. With the OEM Toyota resonator I think the car should sound better.
https://www.youtube.com/watch?v=d_tajogfKAk
Old 07-13-2014, 10:37 PM   #188
salmanghiyas
Fugitive
Very nice
Old 07-17-2014, 05:20 PM   #189
salmanghiyas
Fugitive
if i'm not mistaken ... the point you are making here is ...
the original OEM resonator in the catback which basically is the third one in line ... has 2" in and 2" out pipe width ?
Old 07-18-2014, 10:54 AM   #190
salmanghiyas
Fugitive
Yellowww ...
Old 07-20-2014, 11:54 AM   #191
salmanghiyas
Fugitive
im getting too confused now .. :S
some say go with max 2" pipes some say nah its ok even if u take 2.5" pipes .. some say keep the 1st cat .. same say remove both cats and have only one resonator in between ... :S
im surfing over the forums and internet from the last few days now ... but honestly speaking the more and more im reading stuff the more im getting confused ... :S
i did experimented one thing ... i put a 1.7" pipe ( 1.7" measurement from inside ) from the neck of the headers, removed both cats and resonator till the rear bumper and installed a topspeed muffler at the end ... the inlet of the muffler was 2.5"
Old 07-20-2014, 09:59 PM   #192
Freestylin
Freestylin's Avatar
Drives: 09 Blizzard Pearl RS LB
^ It depends what your long term hp goals are to determine which pipe diameter to go with. Here is a good read:
http://www.magnaflow.com/07techtips/faq/question10.asp
“On a given day, a given circumstance, you think you have a limit. And you then go for this limit and you touch this limit, and you think, 'Okay, this is the limit'. And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high.” ― Ayrton Senna
Freestylin is offline   Reply With Quote
Old 08-31-2014, 11:15 AM   #193
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
finally got around to getting mine back on the dyno with the current exhaust...no real difference over the old set up peak vs. peak...but after peak power was up like 7whp...
http://www.youtube.com/watch?v=yRBfjMLSNDU
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 09-28-2014, 12:25 AM   #194
clint
Drives: 2012 toyota yaris le
Removed stock muffler and replaced with shown baffle and tip. I think it sounds pretty good!!
clint is offline   Reply With Quote
Old 10-21-2014, 07:30 AM   #195
ryanww
Drives: Yaris 1.5L 5 doors
I have 1.5 Yaris m/t. I'm going to install unichip q+, but I'm waiting for the exhaust set up. I've done porting polish, open filter, megan header, lightweight crank pulley. The megan header outlet is 2". What's the best pipe size and exhaust set up? Is 2" mid pipe all the way until the muffler? Or should i put an oem resonator in the middle? I've tried 1.75" and i put the oem resonator in the middle, but the acceleration was not good. Then i put off the resonator, so it was 1.75" all the way to muffler. It was better than with the resonator. I thing it's because the porting polish maybe. Is there anyone has done some research about the pipe size with piggyback install? How much hp and torque was it?
Sent from my iPad using Tapatalk
ryanww is offline   Reply With Quote
Old 10-25-2014, 04:57 PM   #196
Rakin
Drives: Toyota Premio NZT240
Just did a full 2" custom Stainless Steel downpipe with flowmaster 40 series endbox. Removed the cats in the process too since we don't have any emissions testing here whatsoever. OEM resonator. Yes I also did the axle-back section too, forgot to take a photo.
It has a very deep tone, but I would like to quiet it down just a little on the low rev range (upto 3000 RPM?), should I put in another resonator or a high-flow cat to town it down? Any suggestions would be appreciated.
Rakin is offline   Reply With Quote
Old 10-25-2014, 05:02 PM   #197
Rakin
I have the same engine as you do, I did a full 2" pipe all the way and acceleration was pretty good. Felt decent gains over stock system. I did also remove the cats and put a flowmaster in the process though.
Old 10-26-2014, 09:13 PM   #198
ryanww
Thanks Rakin. I will try the 2" pipe.
DIY: Installing Greddy TI-C Exhaust System redyaris DIY / Maintenance / Service 13 08-01-2009 04:05 AM
GReddy prototype = Free Exhaust! Chris_Lum California 30 02-27-2007 10:13 PM
Why is DTM exhaust thread closed? gr8yaris Performance Modifications 4 01-13-2007 11:01 AM
Fujitsubo Exhaust!! MC-BPT Sponsors Classifieds Area 17 11-16-2006 10:36 AM
Toyota Performance Exhaust for Yaris HB bigsky2 Performance Modifications 16 06-02-2006 10:21 AM
