Old 10-21-2014, 12:54 AM   #19
ucsmfu
Drives: yaris le
Originally Posted by Lerico View Post
I use the camera list in post #5. It is designed for Toyota. It's snaps right into the factory camera slot. It's not an universal camera.
are u located in Vancouver, BC as well Lerico ?
ucsmfu is offline   Reply With Quote
Old 10-21-2014, 01:12 AM   #20
Lerico
Drives: Yaris 2012
Nope. Not in Vancouver.
Lerico is offline   Reply With Quote
Old 10-21-2014, 04:38 PM   #21
tomm12
Drives: 2012 Yaris 5D Hatchback
thanks for the pictures Lerico
tomm12 is offline   Reply With Quote
Old 10-25-2014, 01:15 AM   #22
ucsmfu
Drives: yaris le
ever noticed any water leakage or condensation ?
Old 10-26-2014, 02:38 PM   #23
Lerico
Drives: Yaris 2012
No. The camera is just as clear as day one.
Old 11-21-2014, 01:41 AM   #24
ucsmfu
Drives: yaris le
Quick questions, where did you wire the red wire and the black wire for the reverse camera ?
Old 12-11-2014, 03:42 AM   #25
ucsmfu
Drives: yaris le
Originally Posted by Eduardo_mty View Post
ucsmfu, i bought this
http://www.fedomcn.com/sdp/717381/4/...ew_Camera.html.
i cant remove that black plastic cover in the car, then i did a drill, to fit that screw.
Have you installed your reverse camera yet ?
How did you feed the wires through the trunk and into the rubber grommet ?
thanks
Old 12-11-2014, 07:03 AM   #26
Eduardo_mty
Please see the thread , 2015, rear view camera.
And CTScott.. Broken parts
I broked the Rubber plastic.
But i think you can use a long plastic tie
Eduardo_mty is offline   Reply With Quote
Old 12-15-2014, 04:14 AM   #27
ucsmfu
Drives: yaris le
got mine to work :)
Old 05-27-2015, 03:16 PM   #28
screenprinter
Drives: 2010 Yaris 4-door Sedan
Realize this is an old thread. Well, last year anyways.
I'm planning on putting a Back up camera on my 2010 sedan Yaris. I bought wireless adapters so I don't have to mess with the wiring all the way to the front.
It looks simple enough (famous last words). The only real wiring will be from the camera that already has a slot on the trunk. Looks like I have to cut a couple of screw wholes and one cable whole. Then run the cable via the harness under the trunk liner back to the left reverse light. Spice the reverse wires to the the camera. Hope it's that easy. On the other end, I'll hook a 4.3" monitor to the lighter plug, and hope I don't have to use it, lol.
screenprinter is offline   Reply With Quote
Old 05-27-2015, 03:35 PM   #29
screenprinter
Here's a camera I found on ebay: http://www.ebay.com/itm/170-CMOS-Ant..._qi=RTM2067268
I also have the License Plate Frame camera. I'll see which I want to use.
Old 07-02-2016, 10:02 PM   #30
heytim
Drives: 2014 Yaris
Sorry to bump an older thread here, but the camera link in post #5 does not work anymore (well no stock anyway). Does anyone have updated links on a camera that will fit exactly into the pre-made slot?
Have done some searches on ebay and amazon but not sure how well they would fit into the slot
heytim is offline   Reply With Quote
Old 07-03-2016, 03:34 PM   #31
Gagi
Gagi's Avatar
Drives: Yaris 1.33 vvti 2015
http://www.ebay.com/itm/CCD-Car-Reve...EAAOSwQItUL1zm
Gagi is offline   Reply With Quote
Old 07-04-2016, 06:36 PM   #32
heytim
Drives: 2014 Yaris
Thanks! Looking at the pictures it seems right so will probably have to order it and try it out
Old 08-28-2017, 09:42 AM   #33
DarkShadowFox
doesnt the factory camera plug into the DA display headunit?
backup camera! yarismo DIY / Maintenance / Service 10 07-23-2012 01:22 PM
DIY Camera Mount -- No Cost Version KCALB SIRAY DIY / Maintenance / Service 20 06-08-2009 03:12 PM
