#19 |
![]() Drives: Yaris 2012 Join Date: Oct 2012
#20 |
Drives: 2012 Yaris 5D Hatchback Join Date: Oct 2014
thanks for the pictures Lerico
#21 |
![]() ![]() ![]() Drives: yaris le Join Date: Sep 2014
#22 |
#23 |
#24 | |
How did you feed the wires through the trunk and into the rubber grommet ? thanks |
#25 |
![]() ![]() ![]() Join Date: Sep 2014
Please see the thread , 2015, rear view camera.
And CTScott.. Broken parts I broked the Rubber plastic. But i think you can use a long plastic tie |
#26 |
got mine to work :)
#27 |
![]() Drives: 2010 Yaris 4-door Sedan Join Date: Sep 2014
Realize this is an old thread. Well, last year anyways.
I'm planning on putting a Back up camera on my 2010 sedan Yaris. I bought wireless adapters so I don't have to mess with the wiring all the way to the front. It looks simple enough (famous last words). The only real wiring will be from the camera that already has a slot on the trunk. Looks like I have to cut a couple of screw wholes and one cable whole. Then run the cable via the harness under the trunk liner back to the left reverse light. Spice the reverse wires to the the camera. Hope it's that easy. On the other end, I'll hook a 4.3" monitor to the lighter plug, and hope I don't have to use it, lol. |
#28 |
Here's a camera I found on ebay: http://www.ebay.com/itm/170-CMOS-Ant..._qi=RTM2067268
I also have the License Plate Frame camera. I'll see which I want to use. |
#29 |
![]() Drives: 2014 Yaris Join Date: Sep 2015
Sorry to bump an older thread here, but the camera link in post #5 does not work anymore (well no stock anyway). Does anyone have updated links on a camera that will fit exactly into the pre-made slot?
Have done some searches on ebay and amazon but not sure how well they would fit into the slot |
#30 |
![]() ![]() Drives: Yaris 1.33 vvti 2015 Join Date: Nov 2014
#31 | |
#32 |
doesnt the factory camera plug into the DA display headunit?
| backup camera! | yarismo | DIY / Maintenance / Service | 10 | 07-23-2012 01:22 PM |
| DIY Camera Mount -- No Cost Version | KCALB SIRAY | DIY / Maintenance / Service | 20 | 06-08-2009 03:12 PM |
