Old 10-31-2014, 05:55 PM   #1
tmrtza
Drives: Toyota Yaris Hatchback 2010
Steering Wheel Jams, Battery Warning Light flickers, Starting Issues
Hi,
I was on a Traffic Signal when I first experienced my steering wheel totally jammed, very stiff. I went to a mechanic, who advised me to replace Alternator and Battery which I did. Car drove fine for 7-8 days but again i am experiencing the same issues:
1. The steering gets stiff and jammed when the car is standing still.
2. Battery warning light flickers, off and on, on various timings
3. The car is having starting / ignition issues, I cannot start my car.
PS: When the steering wheel jams, i put the car in neutral gear, press the accelerator for few seconds, the steering becomes soft (normal). Also when I press accelerator in neutral gear, the lights go dim and bright as if they are taking current directly from the source related to accelerator!
Any help from any one would be extremely appreciated!!!!
tmrtza is offline   Reply With Quote
Old 10-31-2014, 06:02 PM   #2
Ma71-51o
Ma71-51o's Avatar
Drives: Yaris 5dr HB & 87 Supra turbo
Send a message via AIM to Ma71-51o
Could be the serpentine belt
Fatlace
Illest
HellaFlush
Slammed Society
ExcelFundamentals
Ma71-51o is offline   Reply With Quote
Old 10-31-2014, 08:59 PM   #3
Sounds like you got an aftermarket alternator that doesn't properly feed the signal to the cluster, PS ECU, etc, that the alternator is outputting sufficient power to drive things like power steering.
Old 10-31-2014, 09:01 PM   #4
mitchell12
mitchell12's Avatar
Drives: 2007 yaris HB
I would check all the wiring tof the alternative and battery.
mitchell12 is offline   Reply With Quote
alternator, battery warning light, starting / ignition, stiff steering issues
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
Steering Wheel Issue. Twistoffate0817 General Yaris / Vitz Discussion 8 01-31-2009 07:38 PM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
