Old 11-01-2014, 01:28 AM   #127
"G"
Drives: 2007 Yaris Hatch
Where is the wire for the seat belt alarm?
"G" is offline   Reply With Quote
Old 11-01-2014, 08:52 AM   #128
The driver's side one is under the driver's seat and then it goes under the center console directly to the SRS ECU. The passenger one is under the passenger seat and it goes to the Occupant Classification ECU and then that ECU communicates with the SRS ECU to relay the info.
What exactly are you looking to do with that wire?
Old 11-01-2014, 08:54 PM   #129
wufai
Drives: Silver Yaris Sedan (4A)
So does that mean if I want to steal a yaris like they do it in the movies I need to cut the yellow, pink and black wires and tap the yellow leads against the pink and black?
wufai is offline   Reply With Quote
Old 11-18-2014, 10:10 PM   #130
gabbhie
Drives: yaris sedan
hi CTScott. where can i see the hotwire for parklights that is usually used in aftermarket alarms..when you press the lock/unlock button of alarm the parklight will blink once or twice.
gabbhie is offline   Reply With Quote
Old 11-18-2014, 10:13 PM   #131
Look at my remote start wiring guide for where you can grab the parking light feed. Just verify that the wire colors match, as the Yaris in your market may be wired a bit different.
http://www.yarisworld.com/forums/showthread.php?t=24860
Old 11-18-2014, 10:22 PM   #132
gabbhie
Drives: yaris sedan
oh i see, but i already tried that wire. its not the wire for the parklights.
i have owned my yaris since last year and until now theres no park light signal when i lock/unlock
Old 11-18-2014, 10:34 PM   #133
Post some pictures of the connector for your headlight switch.
Old 11-18-2014, 10:43 PM   #134
gabbhie
Drives: yaris sedan
ok sir i'll post pic once i got home laterTIA
Old 02-04-2015, 12:00 AM   #135
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
CTScott do you have a wiring diagram for the 3rd gen Yaris? In particular I'm interested in the body ECU and what wires go where.
Old 04-08-2015, 10:36 PM   #136
Tunechi
Newbie
Tunechi's Avatar
Drives: 2007 Yaris S Sedan
Which wire is for the fog lights in the light stalk bundle?
And if i splice into that wire and ground it, will i have independent fogs?
(fogs that turn on at any time such as http://www.toyotanation.com/forum/32...od-w-pics.html)
Tunechi is offline   Reply With Quote
Old 08-25-2015, 02:09 PM   #137
Kitt
Kitt's Avatar
Drives: Thndr cl metallic HB 3 drs '05
Send a message via MSN to Kitt
Im planning to add a gauge 2 cable for my amp on my new car from the battery, however, I'm not sure where is the right place to do so. Do I have to drill the firewall?
20 years... alive and kickin'!!
Kitt is offline   Reply With Quote
Old 08-25-2015, 08:45 PM   #138
There is no power feed inside the cabin that you can connect that large of a wire to. You can go through the large grommet that is behind the battery, rather than drilling the firewall.
Old 01-21-2016, 02:27 PM   #139
frankienap
Drives: Yaris 2008 Sedan
Desperately looking for the 12v + reverse wire on the rear tail light
Looking to add power to an aftermarket backup camera. I've searched for over 3 hours for the location of this wire. Here's a picture of the connection for the left rear light assembly on my 2008 Yaris Sedan. Anyone know which wire?
The wires going into the rear lights are: purple, green, orange, white w/a black strip and light blue.
Many many thanks!
frankienap is offline   Reply With Quote
Old 01-21-2016, 03:25 PM   #140
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
If nobody answers, you could get a test light and turn the key to accesories. With the hand brake up, you could just put it in reverse. Use a test light and back probe each wire. Record which ones have power. Then put it back into park and check again to see which one no longer has voltage. I can't look up the wire diagram right now while i am at work. CTScott would be the one to get the info to you the fastest.
-Derrick-
Old 01-21-2016, 04:13 PM   #141
frankienap
I think I'm going to pick up a voltage detector from Lowes tonight. One more question: will I be able to tell which wire coming from the reverse light is positive (versus negative) simply using an analog voltage detector?
Old 01-21-2016, 10:54 PM   #142
Many many thanks!
If you look at the 12 pin connector which connects to the taillight, the red in pin 5 on the right and brown in pin 5 on the left is reverse.
Old 02-16-2016, 09:57 AM   #143
noone09
Newbie
Drives: Vios 2010 1.3E MT
Smile How to add dual usb socket
Hi guys. Just looking to get some help.
Car is a 2010 yaris sedan.
So i want to make use of the 2 empty slots in the center console and add (2) dual usb socket charger and i need your advise on how to connect them.
Here's what i will be getting.
I removed the center console panel to check the cigarette socket wirings.
This is the wiring harness connected to the cigarette lighter socket.
Can i just tap to this cigarette wires?
Any help would be highly appreciated.
noone09 is offline   Reply With Quote
Old 02-26-2016, 03:55 PM   #144
Gagi
Gagi's Avatar
Drives: Yaris 1.33 vvti 2015
Yes, you can "share" power outlet for that dual USB. I took power from the front one on my Yaris.
Gagi is offline   Reply With Quote
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 04:55 AM
New Yaris race car Jason@SportsCar Tracking, Racing, Auto-X Forum 83 11-01-2012 03:32 PM
